Previous in Forum: Setting of X and Y Displacement Probes on a Turbine   Next in Forum: Level Transmiter
12 comments
Wireless Transmitters
05/29/2013 10:10 AM
Has any one use wireless instrumentation for control purpose ? It sounds preposterous but this is more than a curious question. I need to come back and justify why, for purpose of project cost saving, Control and Automation does not peruse wireless instrumentation. The presumption of cost saving is another matter. But for now, is wireless instrumentation ready for control ? Anyone planning to apply it ? Has anyone toy with the idea, e.g using "wireless" valves that has local PID loop (set point control over wireless
Re: wireless transmitters
05/29/2013 10:15 AM
Here's some wireless instrumentation:
and here's a wireless control valve:
and here's a wireless P&ID loop housing doing some modulation according to a pre-programmed algorithm inside it:
05/29/2013 10:44 AM
One of the really nice things about internet searches is that a lot of pertinent information can be gleaned from a few carefully selected words. For instance, if I enter "wireless process control" into the main Google textbox and press <Enter>, I get this.
It's amazing. Really.
05/29/2013 11:27 AM
How did you do that????
05/29/2013 12:15 PM
Re: Wireless Transmitters
05/29/2013 1:20 PM
Look here.
05/29/2013 3:19 PM
No it's quite common now days in certain applications.
05/29/2013 8:44 PM
Yes, this is a preposterous question. The idea that wireless communication in a feedback loop might be a problem immediately implies a whole barrage of questions on what you are not telling us. From the earliest days of satellite communication (Telstar) all communication satellites have been wireless controlled. It has been more than half a century since these birds became functional. So the implied questions hinge on what your concerns and the application that raises these concerns. Are you worried about a hack into your system? Then you should explore secure communication techniques. Are you worried about communication lag? Then a comprehensive time lag analysis should be performed. It is possible wireless communication will impose too much lag. In these rare cases, autonomous closing of a loop locally will allow for remote modification of a feedback loop. Are you worried about a loss of wireless communication resulting in an unsafe operation? I could go on but my point has been made.
You may have a valid concern in your use of wireless, you do not give us enough information to help you.
Good Answers: 59
05/30/2013 7:53 AM
Let me cogitate on the pertinent point:
1,. Engineers spend tons of time, to assure, that what they want, happens, and nothing else happens in the equipment under their control.
2,. Engineer spend tons of time on shielding, grounding, isolating. And testing and verifying the effectiveness of those.
3,. Then along comes a fellow, wanting to open up all that to an unprotected radio link.
I ask the OP, to list a half a dozen things, that can go wrong with the scheme, and its consequences. Before any meaningful conversation can take place, that is.
05/30/2013 9:32 AM
Wireless instruments and communication system can be used in non critical applications, but if there is any criticality due to the comm link failure than go the traditional route hard wiring.
Even though wireless has come a long way I myself would prefer to use hardwired where possible, you have on failure link less.
Mexico - Member - New Member Hobbies - Musician - New Member
05/30/2013 9:55 AM
We are using wireless instrumentation for control purpose, it has been a pain.
The project leader selected wireless for cost saving purposes. I am user of the system and was not involved in the project. There was not enough previous analysis of the environment where it was installed, of the effect of the interference created by the equipment they choose, of the interference the equipment previously installed would cause in the new equipment, etc.
We have many communication loss issues, and a lot of noise and interference with other equipment, due to the location and the chosen equipment we have mayor issues with harmonics in the energy lines…
We are living this problems everyday because of a lack of good analysis in the beginning of the project. If you make a really good and in-depth analysis of your facility, what equipment you have, and what equipment you are going to buy you should not have mayor issues if you select the proper equipment. Wireless instrumentation is not always the best way to go.
"If you want to make an apple pie from scratch, you must first create the universe." Carl Sagan
06/27/2013 6:21 AM
If you use Wireless Instrument for control application It will be too costly, Battery failure is frequent.
07/09/2013 3:37 AM
hi,
Of course you can use a wireless adapter to the existing HART enabled field device to extract HART information and then transmitting it to DCS or direct enterprise level.
Below is the photo of an adapter which can be fitted to an existing device without disturbing its intended functionalities,
The WirelessHART Adapters can be connected directly to the cable gland entry of any conventional HART or 4 ... 20 mA field device. WirelessHART Adapters are battery powered. The adapter supplies power to itself, the connected field device, and provides maximum independence. The adapters operate continuously to provide the router functionality within the network. The field device is only powered when needed. Depending on power consumption, voltage requirements, measurement times, and intervals between measurements, battery life can last for years.
Below pitcure shows the HART Adapter with MESH Network
In a mesh network, devices (nodes) perform double-duty as repeaters to relay data from other
instruments to the gateway as needed. In other words, data transmitted from one WirelessHART
instrument may not be directly received by the gateway device if that path is blocked or too far
away. Instead, the data may "hop" from one device to another nearby, which then re-broadcasts
that information to the gateway via a clearer path.
The purpose of a mesh network is to provide redundant data pathways in case of device failure
or changes in the environment interrupting radio communication between devices. In this way, data
packets may be re-routed to the gateway if the shortest route fails, in a manner similar to how
Terminal Control Protocol (TCP) and Internet Protocol (IP) work together to route data segments
from source to destination over the "mesh" of the Internet. This feature is often referred to in
WirelessHART technical literature as the self-healing property of the mesh network.
According to the HART Foundation, reliability for a well-designed WirelessHART mesh network
is 99.7300204% minimum, and typically greater than 99.9999998%.
Sugessions are welcome.
Register to Reply 12 comments
Heisei (1); jack of all trades (1); Jay16 (1); JohnDG (1); Kilowatt0 (1); leveles (1); lyn (1); Mikerho (1); PWSlack (1); redfred (1); SUHAS227 (1); vargaalex (1)
