Previous in Forum: Air Leak   Next in Forum: Wireless Transmitters
Setting of X and Y Displacement Probes on a Turbine
05/28/2013 4:26 PM
Is it normal protocol to set the displacement probes with the jacking oil on. As it only lifts the rotor by 0.1mm does it really matter?
Re: Setting of X and Y Displacement Probes on a Turbine
05/28/2013 9:33 PM
Can you tell us the acceptable range for the vertical axis value? From that, one might be able to tell whether 0.1mm matters or not.
05/29/2013 3:07 AM
What does the manual say on the topic?
What did the turbine manufacturer say during the telephone call to their technical helpline?
05/29/2013 6:33 AM
you should refer to the technical manual
love4everyone
Hobbies - Fishing - New member but have interest and some experience in fishing.
05/30/2013 5:52 AM
Hello,
I believe that you mean "X and Y Vibration" probes. Yes, because that's the position of the rotor while in operation and you want to be sure about the gap you adjust on the probes.
Screamingsilence
05/30/2013 7:59 AM
Great that is my take on the subject as well but I'm having a hard time making a project manager understand. He's take on it is the shaft would be moving when on jacking oil is on.
JJJ (1); PWSlack (1); screamingsilence (1); sohail0110 (1); Tornado (1)
