Previous in Forum: How to Take Virus Definition Through LAN?   Next in Forum: Plotting GPS points on a map
Excel VBA Program to Close All Running Excel Programs and Open the Current Excel
05/30/2013 8:32 AM
I want to open an excel file containing VBA code. I want to close all running excels and then open the current one. How it is possible using VBA code.
Re: Excel VBA Program to Close All Running Excel Programs and Open the Current Excel
05/30/2013 5:16 PM
05/31/2013 9:07 AM
The problem is if you close all the open Excel files, the one with your VBA code will also close. You can try doing it from Access VBA.
Here's some code to loop through your open workbooks in Excel VBA:
Sub Macro1()
Dim appExcel As Excel.Application
Dim wb As Workbook
'Set application object
Set appExcel = Application
'Loop through open excel workbooks
For Each wb In appExcel.Workbooks
'print workbook name
debug.print wb.name
Next wb
End Sub
Register to Reply 2 comments
