Previous in Forum: Load Sharing Between GTGs of Different Models   Next in Forum: Li-Ion Overcharge Protection Circuit. What is DA?
TNS-Earthing System
06/07/2013 4:35 AM
Hi All,
TNS-Earthing System.
If there is a loss to the Main Earthing(No Electrical earthing at all,Main earth cable disconnected from the main earth terminal)and there is a L-E short Circuit to the MSB.
1)Will the Main ACB/MCCB trip?
2)Will the Earth Fault Relay activated?
Re: TNS-Earthing System
06/07/2013 4:48 AM
1) It may or may not
2) It may or may not
But some body will definitely get a shock or burn injury if they are in the vicinity of the MSB.
Better to ensure there is no loss to main earthing (now what is "main earthing").
06/07/2013 5:00 AM
Hi Pattabhiraman,
Main earthing refer to the TNS earthing where the earth cable connects to the Earth Terminal.
06/07/2013 5:27 AM
Nothing changes with this additional detail.
06/07/2013 5:33 AM
Absolutely.
06/07/2013 5:29 AM
I think it is better to describe it as protective earthing (PE) so as not to confuse with neutral earthing.
06/07/2013 7:35 AM
If there is a loss of earth, no current path and there would no high current and no tripping of ACB/MCCB .
06/07/2013 8:12 AM
Not necessarily. It depends on other system conditions. That's why "It may or may not".
kianhwee (1); Pattabhiraman (4); PWSlack (1); zamanengineer001 (1)
