Previous in Forum: Used Oil Cleaning and Reusing   Next in Forum: How You Will Ensure the Straightness of Mandrel Clamped in the Spindle?
11 comments
Cleaning Polymerization Reactor
06/07/2013 5:06 AM
I'm working in acrylic fiber plant and I face a problem in cleaning the polymerization reactor, the polymer stick on the inner aluminum wall as a hard polymer. is there any way to prevent the formation of this hard material?
Re: polymerization
06/07/2013 5:21 AM
The works' Process Chemist will have a knowledge of the materials and their interactions that is probably commercially sensitive and therefore unavailable to contributors to this forum. The Process Chemist needs to be involved in the first instance to determine the difference between hard polymer and non-hard polymer, and the circumstances that favour the formation of the undesirable material over the desirable. This is laboratory work.
Once the remedy has been determined, pilot-scale trials of changed materials and practices need to take place to verify the remedy before scale-up. At this stage, involve the works' Process Engineer. Any modifications to existing plants and processes then need to pass through a full HazOp Study before implementation at full-scale.
Good luck.
Re: Cleaning Polymerization Reactor
06/07/2013 9:32 AM
Is the " hard" polymer reacting with the Al walls? Or just sticking?
Teflon coating comes to mind, but not knowing the specifics there's not much more to say.
Agree with Slack. Ask the chemist, unless YOU are the chemist.
06/08/2013 3:53 AM
it just sticking, and there's no one (in my co.) know how to stop formation of undesired and hard polymer, that's why I'm asking.
by the way I'm chemical engineer.
06/08/2013 10:07 AM
There's your problem.
06/10/2013 3:49 AM
Somewhere in the archives there should be a process description document that was created by the design team, and that document will have the Process Chemist's input to it. There will also be a Commissioning Report document. Find those documents, read them, and discover why the process is doing what it is doing now instead of what it was doing at the time it was commissioned.
Good Answers: 32
06/10/2013 7:50 AM
What if it is a stolen technology without documents and without proper know how information? These days tea shops and engineering workshop look almost alike. Lots of things are cooked up and you see all this mesh all over. Perhaps a new engineer may not have access to the documents as company may like to protect their some vital secretes. I think this person should tell why he does not have access to the company documents. Is he asking you to do that job?
06/10/2013 4:14 PM
actually I think so, and I search for this for my self because I want to over come this problem which delay the start up and takes more efforts to clean it manually.
06/08/2013 2:33 PM
I agree. Also, remember that Teflon has operating temperature restrictions and they might be exceeded during use of the Polymerization step; that depends a lot on the type of polymer reactor and how it is operated.
06/08/2013 2:35 PM
Well,
We shouldn't have to tell that to a chemical engineer, should we?
Good Answers: 32
06/08/2013 6:11 PM
More than 300C for PTFE is sure a problem. At 400C it decomposes. There is softening after 250C which may result into bulging and deformation of the surface in thick films.
Good Answers: 32
06/08/2013 6:05 PM
Acrylic may get soften and also dissolve in Acetone and perhaps then you can remove it. This can work on room temperature itself. It may also be possible for you to recover Acetone from debris. If your chamber wall is also of similar material then be careful. We never clean PCB with Acetone as it may dissolve some plastic parts. It can also leave some white residue on the surface but not sure about its chemical contents that may be left on the surface. You can see this even on your hands if you clean in Acetone. May be a second cleaning in Ethyl Alcohol can be done.
Register to Reply 11 comments
ahmed.abdelgawad (2); Anonymous Poster (1); lyn (3); PWSlack (2); Shyam (3)
