Previous in Forum: Reducer right?   Next in Forum: Rubber Belt Conveyor
Oil seal
06/01/2007 12:45 AM
Can you help us to design a Oil seal to the following type of drive system
a. Application Details : Food Processor
b. Housing diameter - Less than 16mm, Shaft diameter and Height - 10 h7, N4 finish & 40mm (SS-304), Speed of the shaft - 22000 rpm.
c. Fluid to be sealed - All Liquid food item - Juice, Masala & Dry items like Turmeric
d. Temperature and Pressure : Around 50°C above ambient & No extra pressure other than ambient
Good Answers: 183
Re: Oil seal
06/02/2007 10:10 AM
I am sorry but do not understand you mention an "oil seal" and the kind of liquid to be sealed is not oil. So please be more precise:
-do you want to seal the liquid mentioned?
- do you want to avoid the ingression of oil into the mentioned fluids?
The design is different if you want to avoid liquids going out or liquids coming in. Please make the choice and give the information.
Re: Oil seal
06/04/2007 4:44 AM
Would you like to send me more details about this products, Thanks!
Re: Oil seal
06/04/2007 6:08 PM
22000 rpm?
Pineapple
Re: Oil seal
06/08/2007 10:15 PM
From the description provided you are trying to build a wet or dry grinder for spices, fruits & other food stuff.
You might be better off designing your cutting/grinding blades ala washing machines where in the the center shaft & the container rises above the the food level & the cutting blades are shaped in a kind of conical fashion with the blades at the bottom edge of this conic.
You will save your self a lot of heart burn, maintenance & contamination problems. You can then simply use high quality sintered self lubricating bronze bushes.
Check out some of the coffee bean grinders on the market & you will get the idea.
Good Answers: 183
Re: Oil seal
06/10/2007 2:04 PM
I think your question was in fact not serious. You only wanted to test a reaction. If you really need help you answer questions for detailed informations more rapidly. So that you silence gives me the above mentioned feeling. Good luck to you.
Anonymous Poster (2); nick name (2); pmshah (1)
