Previous in Forum: Removing Alkaline Battery Fluids and Corrosion   Next in Forum: Difference Between Sulfur and Silicone in A184M Steel
8 comments
Inert Gas Requirement
06/10/2013 3:00 AM
Dear Sir,I would like to know about estimation of inert gas required when there is solids flow.for typical situation, bunker feeding solids to extruder. we know extruder throughput.
for liquid, as per API 2000 std is 0.94 nm3/hr of air as inbreathing requirement per m3/hr of liquid outflow. So, for solids does the same ratio applies ?
Would like to know, how we arrived that 0.94 nm3/hr of air for m3/hr of liquid outflow required?
RegardsBhalchandra
Be not afraid of growing slowly, Be afraid only of standing still.
Re: Inert gas requirement
06/10/2013 3:19 AM
Please describe the solid and its particle size. What is the ST number in terms of its explosivity?
06/10/2013 3:59 AM
06/10/2013 5:46 AM
Dear Sir,
Solid is Phosphorous pentasulfide, particle size is powder form ( appx. 100 - 200 microns ).
About ST no. or dust explosion class information not available.
But, mini. oxygen conc. is 2% by vol.
Regards
06/10/2013 6:35 AM
"About ST no. or dust explosion class information not available."
Really??? Do you not have an MSDS for this? I just read the MSDS and Phosphorous Pentasulfide dust is extremely explosive in air. At only 0.05% by volume.
06/10/2013 6:56 AM
Dear Sir,
In MSDS from Sigma Aldrich, P2S5 forms explosive mixture with air at 0.5% wt / vol.
Regarding ST no. i have not found any data.
06/10/2013 6:54 AM
<...mini. oxygen conc. is 2% by vol...>
Minimum or maximum?
Once that number is established, the inerting question responds readily to a little arithmetic.
As above #4↑, the Material Safety Data Sheet contains much valuable information. A Google search will reveal it.
06/10/2013 7:05 AM
Dear Sir,
It is given as desired safety margin of appx. 2% by volume. So, it is maximum oxygen concentration.
Regards
06/10/2013 8:45 AM
Good luck with the arithmetic.
Register to Reply 8 comments
bhalchandra (3); JPool (1); PWSlack (4)
