Previous in Forum: Difference Between Sulfur and Silicone in A184M Steel   Next in Forum: A Czochralski Crystal
8 comments
Neutralizing Sodium Cloride in Antique Autos
06/10/2013 1:51 PM
I've googled this, and can find products for sale (e.g. USA Eastwood), but is there any COTS products that can neutralize salt that has tunneled into the surface of sheet metal body parts?
I've sandblasted and then find minions of rust spots that must be growing from pin holes where the salt has buried itself from removal.
Now I'm assuming the treatment does not cause new problems.
Good Answers: 444
Re: Neutralizing Sodium Cloride in Antique Autos
06/10/2013 2:43 PM
There's a bunch of them out there, simply Google on Rust Sealant. I've used this with great results:
http://www.por15.com/POR-15/productinfo/1GB/
06/10/2013 11:53 PM
We use windex in the gun business to neutralize affects of corrosive ammo which produces the same salts .I believe the active ingredient is actually ammonia.
I would assume spraying down with windex or your own solution and rinsing would do it.
Lighten up
Good Answers: 58
06/11/2013 9:36 AM
I'm not sure what the corrosive salt residue is on ammo, but can tell you that ammonia is very corrosive to brass cartridge cases. The British learned that the hard way in India.
06/11/2013 1:07 PM
The solution is sprayed down the barrel after firing it is recommended to wipe out or rinse with water .
Lighten up
06/11/2013 7:41 AM
You can have them chemically dipped if you're doing a restoration.....
Good Answers: 22
06/11/2013 12:54 PM
Almost all corrosive salts found on vehicles are somewhat water soluable and that is why they corrode when exposed to water. Our approach on a current vehicle and what I will be doing once I decide on a product (I too am investigating Eastwood products) will be to pressure wash the frame after cleaning it as best I can and then rinse with distilled water which is slightly acidic and allows a formation of a different iron oxide and immediate drying by rags and air, then apply the protective coating both inside and outside the frame. I will only use sandblasting when I have to because the body is fiberglass and will need protection when I do. I will probably do a few feet at a time, (hey, I'm retired, work is a four letter word) and I may experiment with doing what sandblasting is needed before starting or just before painting.
The biggest problem I have is finding technical or user information on the various products. All the suppliers say their product is best, but give little to back it up. The main thing I have found is that the heavy tar based products are worse than doing nothing at all. The various paint products have promise as do the fairly plain metal preps based primarily on phosphoric acid. This does seem to etch the metal and improve adhesion. I have used it on car bodies in the past and had good results.
If anyone has used any products for frames, I would be glad to hear comments good and bad. Currently I am looking at Eastwood and KBS products but will include any others I can find.
06/11/2013 8:30 PM
Tequila and cointreau?
06/11/2013 8:55 PM
Salts ARE neutral many are still corrosive. You need to remove the salt not neutralize it. Phosphoric acid will change the rust to a more stable iron phosphate. It is in several rust treatment products.
4wsilver (1); aDIYguy (1); Brave Sir Robin (1); corbinstein (1); RAMConsult (1); traditional (2); welderman (1)
