Previous in Forum: Differential Pressure Gauge   Next in Forum: Instrument Manifold
Level Stub Size
06/12/2013 6:49 AM
I have to measure level in condensing pot . the hole size in pot is 10 mm, but level stub is 25mm ID pipe with DN25 valve. wat rectification can be done . whether there is any standard for level hole just as 10mm for pressure hole.
Pathfinder Tags: field instrumentation level
Good Answers: 176
Re: Level Stub Size
06/12/2013 8:28 AM
There is no 'standard' for a port size on a condensing pot. The port size is what it is.
If the centerline offset between the existing 25mm port and your desired 10mm port actually makes a difference to level measurement technology you intend using and the results that technology will provide (7.5mm), then have an adapter fabricated that places a 10mm port at the appropriate location.
Re: Level Stub Size
06/13/2013 12:03 AM
Whether level measurement will affect if i put adapter of 10mm to 25 mm to match my level stub.
Re: Level Stub Size
06/19/2013 3:17 AM
See #1↑. If in doubt, talk to an experienced Instrument Technician.
Register to Reply 3 comments
Iris (1); PWSlack (1); Vijayeie (1)
