Previous in Forum: Best Coating for an Amine Storage Tank   Next in Forum: What is PSA North?
8 comments
Sandblast Stainless Steel by Silicate
06/17/2013 5:28 AM
Can we sandblast stainless steels body of pump with silicate's sand or not ?
Re: Sandblast Stainless Steel by Silicate
06/17/2013 3:10 PM
Sure, why not, but why do you want to, does it need cleaning or paint removal or something?
06/18/2013 2:22 AM
yes we want reblasting by silicate sandno by and then painting again
06/18/2013 3:16 PM
Then go ahead (unless anyone here on CR4 knows something I don't that would make this potentially a bad idea in this particular application).
Good Answers: 32
06/20/2013 11:51 PM
Sand blasting and ultrasonic cleaning and drying before next painting process is usually done. Sand grain size is important and perhaps to start with course and then fine grain will be ideal for good finish. If you wish to retain roughness on the surface for paint binding then do not use very fine polishing finish else paint will simply peal off easily.
If you do ultrasonic cleaning then use low frequency 25kHz frequency ultrasonic cleaner which will keep the surface roughness and remove the sand grains.
Good Answers: 243
06/26/2013 1:38 PM
Only if you have NOT used the same equipment for blasting carbon or alloy steel. If there is any carry over of iron/steel particles they can become embedded in the stainless bodies and will nucleate corrosion cells.
So the quality / purity of the sand (free from iron) is important.
Or else you can plan on repassivating after the blasting .
Milo
06/27/2013 10:56 AM
There are other media that may be better than sand for this purpose.
Glass beads are commonly used for this purpose. Sodium bicarbonate and even ground walnut shells can be used to remove paint without fear of metal erosion.
Dry ice is also used when erosion or contamination is a concern.
Sand would be my last choice.
Good Answers: 243
06/27/2013 2:27 PM
Actually alloy steel shot would be my last choice, but you are correct to suggest other media, Lyn. Not sure if many of those are available locally there.
Milo
06/27/2013 3:54 PM
How true. I'm sure they have plenty of sand in "south arabeia" . I'm assuming that Arabia is the location.
I might even be inclined to chemically strip it. Less chance of residual abrasives that way.
Register to Reply 8 comments
bahman (1); jack of all trades (2); lyn (2); Milo (2); Shyam (1)
