Previous in Forum: DC Motor Field Coils Getting Overheated Often   Next in Forum: Earthing Switch In the High Voltage Panel
ML370 G5 Spare Parts For ML350 G5 Server
06/19/2013 4:14 AM
Dear All,
We are using HP ML350 G5 server. Can we use ML370 G5 server's spare parts for ML350 G5 Server. Anyone having experience on these servers. kindly help
Re: ML370 G5 Spare Parts For ML350 G5 Server
06/19/2013 8:29 AM
06/19/2013 9:15 AM
Gee, that takes all the fun out of the process.
Following your advice, OP might never get to see the magic smoke contained in many components these days.
06/19/2013 9:42 AM
The question remains: is that a Good Thing or a Bad Thing?
06/19/2013 10:48 AM
Yes, quite!
06/20/2013 2:30 AM
Definitely a good thing or a bad thing. Depends. Is the server half empty or half full?
06/20/2013 3:53 AM
It can't quite be seen from here.
United States - Member - NE, USA Hobbies - Target Shooting - New Member Engineering Fields - Aerospace Engineering - Engineering Fields - Electromechanical Engineering - New Member
06/20/2013 8:11 AM
In absence of any factual data, the only remaining method to determine the answer is experimentation.
I would totaly just use parts and see if they worked.
As someone indicated above - if magic smoke emits... it didn't work.
Register to Reply 7 comments
Deefburger (1); JCase (1); lyn (2); PWSlack (3)
