Previous in Forum: Where Can I Find RMU?   Next in Forum: Motor Won't Run Under Load
Analog Electrical Measuring Meters
06/20/2013 2:17 PM
On elctrical measuring meters some symbols are written.I understand the symbols for Moving coil and moving Iron.Also ac and DC symbols can easily be understood. But some symbols like "inverted T" , symbol of star in which 2 is written within, symbol of one sine wave and 1 written near it, Symbol of 3 sine wave and 1 written near it, and square wave symbol meaning is hard to understand. Kindly help.
Also please help in knowing where moving iron and where moving coil meters are used.
Re: ANALOG ELECTRICAL MEASURING METERS.
06/20/2013 2:27 PM
It would help us if you identified the meter by manufacturer and model number, where these symbols are found on the meter, or provided us a picture of the meter with the symbols. Telling us only what you do not understand does not help us help you.
06/20/2013 2:51 PM
Can you provide a photo?
Good Answers: 181
Re: Analog Electrical Measuring Meters
06/20/2013 9:08 PM
Inverted T is a moving coil meter.
The 2 in the star is its voltage in KV withstand to earth.
Square wave is either peak to peak or average.
The others you will have to post pictures of, but I think they refer to √2 RMS and peak voltage.
06/21/2013 9:49 AM
I hate pictograms. I don't know what half the switches in my car do.
06/21/2013 12:22 PM
There are many different symbols that can be on the scale of an analogue meter.
The inverted 'T' shows that it has been designed to be mounted vertically;
A star with a number indicates the basic accuracy of the movement so the 2 would be for a movement with 2% accuracy.
The sine wave with a number next to it is to show that it has been calibrated with a pure sine wave with a crest factor of 1.
The square wave is a puzzle, are you sure its not a sign indicating resistance? Especially of a shunt resistor used to extend the range of the meter.
Best I can do with the information ~ John.
Electroman (1); harley (1); jack of all trades (1); redfred (1); TonyS (1)
