Previous in Forum: Pressure Required to Press Bearings on a Shaft   Next in Forum: rotary engines. e.g. mazda/wankel
Which Velocity Measuring Instrument Will Help My Setup?
06/21/2013 2:12 AM
I want to find out the actual flow across a rotary valve whose are is keep on changing. As the area changes, flow also changes. I want to measure this change. FLOW IS OSCILLATING (Cyclic). Fluid is Helium and Cycle time is around 0.25 - 1 second. I want to measure the flow rate at each small time step (If I divide cycle time into 100 parts.).
As the flow is product of area, density and velocity. I want to know how to measure velocity? Which instrument will give me velocity after such a small time step? Please provide details.
Paresh B. Gujarati
Re: Which velocity measuring instrument will help to my setup?
06/21/2013 3:38 AM
How about a pitot tube?
It really would help to have some useful real-world data on this thing. Line size would be a good start, as would temperature and pressure.
Good Answers: 59
Re: Which Velocity Measuring Instrument Will Help My Setup?
06/21/2013 11:33 PM
The most charitably I can look at this is a poorly presented homework. Helium, as a liquid (I presume, by necessity) is CRYOGENIC in a bad way. It is handled by verrry experienced PhD's and their verrrry experienced engineers. Not in need of advice from us.
Poor idea of a discussion.
06/23/2013 1:18 PM
How about ultrasonic flow meters ?
06/25/2013 7:27 PM
@-270C that's some pretty trick stuff, sure you wont freeze your fingers off???
Register to Reply 4 comments
Fredski (1); leveles (1); PWSlack (1); sivaa (1)
