Previous in Forum: 7.1 vs 5.1 Surround Sound   Next in Forum: Perhaps Smartphones Are Getting Too Smart...
9 comments
India - Member - New Member
Water Technology
06/22/2013 10:00 AM
if it is possible to charge the mobile in water using water technology
Re: water technology
06/22/2013 10:16 AM
Please elucidate.
06/23/2013 9:05 AM
Can you do that in public?
06/23/2013 11:14 AM
It pretty hard to do it even in private!
06/22/2013 10:25 AM
Not problem if your electricity comes from hydroelectric power generation, you are using water technology to charge your mobile phone.
Do not dip your phone in water and expect it to recharge.
07/07/2015 9:44 AM
thank u
12/23/2019 5:02 AM
Thank u
Re: Water Technology
06/23/2013 3:26 AM
If you were in an electric submarine whose batteries were charged with hydroelectricity and you had a mobile phone charger and adapter, then yes....of course you would probably need a remote antenna floating on the surface and connected your phone to get a good signal....
06/23/2013 3:49 PM
Do you mean like using water activated battery cells or something?
Technically that isn't charging thou.
01/06/2020 10:14 AM
If you have one of these phones, you might actually have no water. After switching off the phone, start removing everything possible. Gently shake the phone to get rid of any water present in the headphone jack, charging port or under the ... This is one of the most commonly used and known techniques.
Register to Reply 9 comments
bebelynaccessdoors (1); chandanakala (2); jack of all trades (1); lyn (2); SolarEagle (1); Tornado (2)
