Previous in Forum: Pnoz Relay   Next in Forum: Power Factor Formula
Wind Turbine
06/23/2013 11:17 PM
what is the formula to calculate the number of blades against output power?
Pathfinder Tags: Wind Turbine calculate
Re: Wind Turbin
06/23/2013 11:45 PM
1 blade gives one to one power.
2 blades gives 2:1 power.
3 blades gives even more than the first two.
4 blades is pushing it,
5's too many.
Google "wind turbine blade efficiency".
Wind turbine design - Wikipedia, the free encyclopedia
Re: Wind Turbine
06/24/2013 8:42 AM
Jacobs (the inventor of cathodic protection) stated that 3 is optimum.
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
Re: Wind Turbine
06/24/2013 2:18 PM
One blade, not very efficient
two blades, 10% more efficient than one blade
three blades, 5% more efficient than 2 blades
tip speed ratio(TSR) = Blade tip speed over wind speed
Ideal TSR is between 6-8 for typical 3-blade industrial wind turbines. In this range, the most possible power is being extracted from the wind.
Example of what happens with blade spin overspeed....
http://www.youtube.com/watch?v=QL-cRuYAxg0
http://cgcc.us/sites/cgcc.us/files/advising/Wind%20Turbine%20Blades%20-%20102.pdf
Re: Wind Turbine
06/24/2013 2:26 PM
Very good.
My answer wasn't backed up by a lesson plan.
Register to Reply 4 comments
lyn (2); ronclarke (1); SolarEagle (1)
