Previous in Forum: SACE Tmax MCCB   Next in Forum: Wind Turbine
9 comments
Pnoz Relay
06/23/2013 5:05 PM
power led blinking on a pilz pnoz relay
Pathfinder Tags: pnoz
Re: pnoz relay
06/23/2013 6:14 PM
First: Do you have a question?
Second: Have you even tried the manufacturer's website? https://www.pilz.com/eshop/b2b/publicinit.do?category=A0011B0018&language=en
Re: pnoz relay
06/23/2013 6:54 PM
Read the manual.
Re: pnoz relay
06/25/2013 8:45 AM
Since I've used these, as well as two other company's models that are the same thing with different labeling, my first thought was I agree with you, but since I am a bit curious as to why one would ask the question and not read the manual, I had to do so.
Guess what? The manual has absolutely no indication of what the LED's mean. (I read several PNOZ model manuals to no avail) I suspect the LED codes are on the case of the PNOZ, and if mounted on a backplane in a panel, you'll never be able to read the chart.
Re: pnoz relay
06/25/2013 2:48 PM
That would be my guess also, unless it is not included in a separate application note document downloadable off the manufacturer's website. It has to be listed somewhere.
Re: pnoz relay
06/26/2013 10:35 AM
Unfortunately we are both in error - see my post #6 - I actually found one in stock with manual in my stock parts electrical cabinet and there are no codes for what that means.
Re: pnoz relay
06/23/2013 6:58 PM
Errors....Fault conditions are indicated by flashing the LEDs. Some errors are displayed through periodic flashing (see Table 8-1);with other errors it is possible to establish an error code through the number of flashes(Table 8-2).These errors are always indicated by three short flashes at LED CH.1 or CH.2. After a longer pause, the LED will then flash at one second intervals. The number of LED flashes corresponds to a digit in the error code. The error code can consist of up to 4 digits. The digits are separated by a longer period without flashing. The entire sequence is constantly repeated.The error code can also be read into a PLC via the diagnostic output. In this case the error code will appear as a hexadecimal sequence. The process of reading and transferring data to a PLC is described in the PLC Drivers manual.
From 1.8
POWER flashing......Unknown operating mode, initialisation phase, start not executed...Depending on operating mode: Press reset button or perform start-up test
http://www.componente-automatizari.ro/pilz/doc/PNOZelog_Technical_Catalogue.pdf - sorry, link no longer available
Re: Pnoz Relay
06/24/2013 3:11 AM
Blinkin' 'eck!
Re: Pnoz Relay
06/25/2013 9:09 AM
Okay - I checked my stock and to my surprise, I found I have a spare Pilz PNOZ setting there from some old project. No info on the power LED in the manual or on the case. (they only mention the CH1, CH2 LED's) I know it lights solid when things are good. Sounds like a failure to me. Contact Pilz for help.
Re: Pnoz Relay
06/25/2013 1:24 PM
as LED , if checked by giving required voltage ; will that blink or otherwise ?
Register to Reply 9 comments
jack of all trades (2); Kilowatt0 (1); Phys (3); PWSlack (1); sivaa (1); SolarEagle (1)
