Previous in Forum: Help Me with PVC Plastic Grades for Welding   Next in Forum: Tin and Bismuth Melt Holding Tank Material, Suggestions Needed
A387 GR.321 CL1
06/30/2013 2:55 AM
Hi,
Could you please let me have some information about PIPE EFW BE 100% RT NACE MR0175 ASME B36.19M, A387 GR.321 CL1 or any spec for review.
Because i have received the high price for this material.
Regards
Arash
Good Answers: 104
Re: A387 GR.321 CL1
06/30/2013 12:59 PM
I don't have access to ASTM/ASME specifications, but presumably you do? However, looking at the ASTM A387 description online, it mentions 'grades 2, 12, 11, 22, 22L, 21, 21L, 5, 9 and 91', but no 321. Maybe the spec has changed, or your purchase spec is in error. Are you trying to obtain 18Cr-10Ni-Ti material? This is a plate spec, and you reference NACE MR0175 which addressed hydrogen service, so that would indicate a stabilized stainless steel pipe rolled from plate for hydrogen service, right? No wonder it is expensive. (Actually, I think A240 Standard Specification for Chromium and Chromium-Nickel Stainless Steel Plate, Sheet, and Strip for Pressure Vessels and for General Applications is the correct spec for 321 material, but, again, I don't have access to the specs.).
Are you the procurement agent or the specifying engineer?
Good Answers: 104
Re: A387 GR.321 CL1
06/30/2013 1:04 PM
Actually, I suspect "ASTM A312 / A312M - 13a Standard Specification for Seamless, Welded, and Heavily Cold Worked Austenitic Stainless Steel Pipes" should be considered in there, somewhere.
Re: A387 GR.321 CL1
07/02/2013 6:05 AM
Thanks for your Guidance, this inquiry received from customer as you know all of engineer use standards in order to find out spec details but for this material i have confused.
For sure material A387 used for Hydrogen services and the price too much high.
Re: A387 GR.321 CL1
07/01/2013 3:18 AM
Declined. Try using an internet search engine, such as Google, instead.
Re: A387 GR.321 CL1
07/06/2013 2:14 AM
Thanks for your clever response and take care of yourself.
arrri (2); bigg (2); PWSlack (1)
