Previous in Forum: Finishing Plating and The Meaning Of MFZnFe5-C   Next in Forum: A387 GR.321 CL1
10 comments
Help Me with PVC Plastic Grades for Welding
06/28/2013 5:33 AM
Hi every body.
I need to weld the seams of PVC plastic sheet and want to have the flexible and soft seams after welding.
Is it possible to use PVC plastic welding rod?what kind or grade of PVC welding rod is exist and be reasonable for me?
you know I got some PVC welding rod but after welding the seams became so hard.the flexibility is crucial for me.
Re: Help Me with PVC Plastic Grades for Welding
06/28/2013 6:50 AM
Someone must know how to do it, otherwise all the waterproof clothing manufacturers would be out of business:
06/28/2013 11:36 AM
Most of these thin things are ultrasonically welded, using no filler materials.
I'm assuming this person has a thermoplastic welding gun.
Plastic Welding Kit with Air Motor and Temperature Adjustment
Filler material is added by the operator, by hand, just like tig welding metal.
More than you wanted to know, I'm sure.
06/29/2013 2:23 AM
Hi Lyn,
You might want to look at the product review at the site you linked to for the welder. It apparently is a very defective product, not viable. Was there another one you could suggest?
06/29/2013 10:02 AM
Dan,
The gun I referenced was an example of an inexpensive gun that required no air compressor to provide the air flow needed for thermoplastic welding.
It was not an endorsement of the product.
I'd use Wegener Autotherm Welder or Wegener Duratherm Welder if I wanted the best results.
But, even the best gun won't assure correct penetration and welding speed. The operator is still the most important tool in the tool box.
By the way, take your BIG check book along if you want a top quality welding gun.
AUTOTHERM WELDER WITH 26FT CABLE & AIR HOSESPARE HEATING ELEMENT 120V/800WTEMP GAUGE WEG 06N - DIGITAL
$1438.79
$1438.79
06/29/2013 2:33 PM
Thank you Lyn,
Point well taken
06/28/2013 8:54 AM
Ask for FPVC (Flexible PVC) rod if you went flexible joints.
Professional Plastics (Disclaimer) carries it, as do other plastics suppliers.
Doen't anybody use a search engine for this simple stuff?
06/28/2013 9:18 AM
Doen't anybody spell check their replies?
06/28/2013 9:56 AM
now-one!
06/28/2013 1:01 PM
Thanks for your reply.
Do you any information about the the Grade of FPVC?
06/28/2013 1:12 PM
No, never used it. All my work was welding (I didn't actually DO the welding) 1 inch thick rigid PVC to make large chemical tanks and process machines.
Go to the supplier's web site.
Or, call them up on a phone.
Register to Reply 10 comments
Dan A (2); faranak (1); IdeaSmith (1); lyn (5); PWSlack (1)
