Previous in Forum: Piping Question   Next in Forum: CO2 Tunnel
Automatic Brinell Hardness Testing
07/10/2013 2:11 AM
Fully Automatic Heavy Duty Hardness Tester. We need to measure Brinell hardness in less than 10 secs for thousands of components daily. A automatic Brinell tester with an image analyzer software is also not giving the required productivity. Any cost competitive solutions?
Pathfinder Tags: automation Brinell Hardness
Re: Automatic Brinell Hardness Testing
07/10/2013 5:03 AM
Split the component stream and use many automatic tester in parallel.
Sorry nothing will be cost competitve at a point were automatic testers fail.
07/10/2013 9:22 AM
If the mass is great enough and the surface is smooth without surface tension then something on the order of an Equotip (i am not affiliated) could be automated. I believe the newer models have a digital output.
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
07/10/2013 11:50 PM
Your information is not complete. How big are the parts to be tested? When you say 'Fully Automatic Tester' does it include loading / unloading of components? What is the bottleneck in the testing process? It can hardly be the vision system as grabbing an image and analyzing it would take only a fraction of a second. In my opinion (I build vision systems for a living) if the part is small (up to a few hundred grams) doing the hardness test within 10 seconds should not be a problem.
You cannot change the wind but you can adjust the sails
07/23/2013 1:37 AM
if it possible to pass parts (within close tolerances ) between two rollers one of them for support & other heaving hard-indentator(pointer )with sensor/transducer like strain gauge which will give hardness value ?
if material is same but diff. in hardness due to mfg. process & workpiece heaving same shape then try for nonconventational method like Ultrasonic , Electromagnetic... With C.R.O.
Register to Reply 4 comments
Anonymous Poster (1); IdeaSmith (1); kishor_durve (1); ronclarke (1)
