Previous in Forum: RE: Heating Lead Antimony   Next in Forum: What are the Harmonic Frequencies of the Sodium Ion?
Regeneration Flow Rate Calculation For DM Plant
07/10/2013 3:17 AM
Hi ! I am working as design/proposal engineer for water treatment plant. I am not getting the calculation for finding regeneration flow rate. If any one knows please help me to calculate the regeneration flow rate for DM plant ?
Re: Regeneration flow rate calculation for DM plant
07/10/2013 3:39 AM
Regeneration flowrate for what equipment, exactly?
  • For a filter vessel containing granular materials, the regeneration or rather backwash flowrate is restricted to below that needed to fluidise the media material so that it leaves the vessel via the backwash outlet valve; the flowrate is usually restricted by having an adjustable mechanical stop on that valve that is set and locked during process commissioning activity.
Re: Regeneration Flow Rate Calculation For DM Plant
07/10/2013 11:41 PM
What do you propose to pay for this information?
First, you will have to provide sufficient information to get help from any source.
Try this free site.
Resin Regeneration Fundamentals | Water Quality Products
Be sure to give them credit for your work.
07/11/2013 11:32 AM
The only thing I would add to Lyn's comments is this:
The flow rate for regeneration of a demineralizer plant depends on the type (and size) of the equipment. Usually for a two bed cation/anion system of the older co-current regeneration type, the regeneration flow rate will be 35-45% of service flow rate. For a counter current regeneration two bed system this might be slightly lower, as I recall, but again this depends on the type of equipment and the design of the internals.
For mixed bed demineralizer regeneration, the resin types must be separated, either internally to the vessel, or externally by resin removal, separation, and regeneration. Flow rates of dilute caustic soda and dilute acid will be considerably below service flow, but the answer again depends on the type of equipment as to how low. Too low, and the regeneration performance will suffer, too high same answer, and also possible loss of resin, depending on design.
Register to Reply 3 comments
James Stewart (1); lyn (1); PWSlack (1)
