Previous in Forum: IEC Versus IEEE   Next in Forum: Which Motor Need To Be Installed For High Viscous Applications
8 comments
Why The Generators Are Mostly Star Connected ?
07/10/2013 5:34 AM
Generators / alternators having stator windings as star connected mostly what is the reason for having star winding on stator side. The rotor is a permanent magnet rotating with the constant frequency with prime mover. why on the single line / designs we always prefer star connected generators.
Is this due to
Less voltage stress as compared to delta
Differential protection is easy to configure in star
Re: Why the Generators are mostly star connected ?
07/10/2013 7:25 AM
...or is it to do with the ability to connect single-phase loads to it? Hmmmm.....
Good Answers: 181
Re: Why The Generators Are Mostly Star Connected ?
07/10/2013 7:44 AM
Easier earthing arrangements?
07/10/2013 7:47 AM
Do we need earthing on delta gensets ?
07/10/2013 8:00 AM
Only if protection against electric shock is a consideration.
Good Answers: 181
07/11/2013 8:34 AM
Read the question
07/10/2013 2:05 PM
They are that way for the same reason that my new fiber optic phone, TV, and internet service access point needs a 8 foot ground rod.
07/11/2013 10:32 PM
Star, less insulation of windings needed, which will reduce the size of the equipment,.
Good Answers: 170
07/14/2013 11:38 AM
i) Lesser insulation needed between line & earth (only for phase voltage)
ii) Can connect single phase loads
iii) Can earth the neutral and get the benefits of an earthed neutral system.
electricalexpert65 (1); eltech (1); mik23 (1); PWSlack (2); tcmtech (1); TonyS (2)
