Previous in Forum: Hydraulic cylinders differential flow   Next in Forum: Producing Heat with Pressure Drop
Regarding Turbine Moving Blades
07/12/2013 12:56 AM
I had a question about turbines ...why the turbine moving blades are provided with holes just below the openings provided for steam flow..the turbine manufacturer is Harbin chinese based
Re: regarding turbine moving blades
07/12/2013 3:52 AM
Do this with Harbin:
Re: Regarding Turbine Moving Blades
07/13/2013 2:03 AM
Despite the lack of information or a photograph, I am hazarding a guess that the steam turbine you refer to is having impulse blading.
The holes provided in the discs (underneath the blades) are for equalising the pressure before and after the moving blades. In the absence of these, there is likely to be a pressure drop across the moving blade which may increase the loading on the blade to a level for which it is not designed.
Good Answers: 32
07/16/2013 3:55 PM
GA. None such holes found on Reaction blading sections only on the Impulse sections as there should be no pressure drop across the impulse wheel only at the fixed impulse nozzles (stationary nozzle block).
Spinco
Register to Reply 3 comments
hdevadig (1); PWSlack (1); Spinco (1)
