Previous in Forum: Non Destructive Testing Of Concrete   Next in Forum: Civil Engineering and Job Prospects:
lgnition System GIU 1902
07/12/2013 3:04 AM
Great Bear Stars Techcom Joint Stock Company - GBS.,JSC introduce a product Ignition System GIU-1902. This product is a system for igniting gas or a fuel-air mixture.
1. Technical specification
ü Power supply: 110VAC/ 230VAC (±10%), 50/60Hz
ü Output: 02 electrical outputs suitable for application to the spark plug
ü Stored energy: 8 joules of energy for discharge at each spark plug
ü Spark repetition rate: approximation 1 spark/second
ü The enclosure made from stainless steel
ü Cable entry: 01 cable gland M20 for AC power supply cable
ü 02 High voltage connector (Female).
ü IP Rating: IP65
ü Environmental: Operating Temp.: 0 ÷ 50 ⁰C
Storage Temp.: 0 ÷ 85 ⁰C
Relative Humidity: 0 ÷ 90 %RH (non-condensing)
2. A complete system includes the following items
ü 01 High Energy Ignition Unit
ü 02 High Energy Igniter
ü 02 Gas Pilot Light
ü 02 High Energy Cables
ü 01 Flame-resistant Power Cable
ü 01 IP65 Start box
3. Application
ü Ignition for crude-oils and gas during well test operation
ü Ignition for ceramic furnace, cement furnace, glass furnace, iron and steel furnaces ...
4. Successful Stories
Due to high quality of Ignition System GIU-1902, many leading Oil and Gas Corporations in VietNam trust to use. The product have also been exported to Indian, UAE, Indonesia…
Nguyen The Son
Great Bear Stars Techcom Joint Stock Company (GBS.,JSC)
