Previous in Forum: 4-20mA Conversion   Next in Forum: Information About Abbreviations Used in P&IDs for Denoting Different Instruments
8 comments
System Fault In Siemens AI Module
07/15/2013 11:35 AM
What are the possible cause for SF in siemens AI module 6ES7 331-7TF00-0AB0?
Re: System fault in siemens AI module
07/15/2013 11:47 AM
07/15/2013 12:18 PM
Fuse is ok
07/15/2013 3:04 PM
Well then if the fuse is OK and you cannot diagnose the problem to any further depth then I suggest replacing the module would be your best option.
Re: System Fault In Siemens AI Module
07/15/2013 6:41 PM
07/15/2013 8:22 PM
Ha ha, didn't you hear him, the fuse is OK!
07/15/2013 8:37 PM
He asked for, "the possible cause for SF in siemens AI module".
I referenced a, "possible cause for SF in siemens AI module".
Didn't have much interest anyway.
Seems to me Siemens would be the place to go, as you suggested.
07/16/2013 6:01 AM
Your link seems quite similar to mine.... Although the op didn't seem to get that the link was to the forum at Siemens, and not necessarily as a specific cause of failure....
07/16/2013 3:09 AM
A lack of willingness to recycle and replace it would be one possibility.
Register to Reply 8 comments
jack of all trades (1); lyn (2); PWSlack (1); sakthi_201086 (1); SolarEagle (3)
