Previous in Forum: System Fault In Siemens AI Module   Next in Forum: Grounding
Information About Abbreviations Used in P&IDs for Denoting Different Instruments
07/15/2013 2:12 PM
Can anyone help me how can I find out abbreviations for different instruments shows in P&Ids??as as example..NZSC stands for limit switch..NPT for pressure transmitter....etc..
plz help me to find out whole abbreviation directory..
Re: Information About Abbreviations Used in P&IDs for Denoting Different Instruments
07/15/2013 3:10 PM
Tips for Posting on CR4:
Good Answers: 104
07/15/2013 4:40 PM
There should always be a legend sheet with abbreviations and numbering schemes for equipment, instruments, piping, etc.
07/15/2013 5:27 PM
I'm betting OP has no instruments.
Sounds more like homework to me.
Or, maybe he's interviewing for an instrument tech job?
07/15/2013 5:38 PM
I'd be curious how they get NZSC to stand for a limit switch....
And NPT to be other than National Pipe Thread.
07/15/2013 5:55 PM
It's in code. You need a secret decoder ring.
Be sure to drink your Ovaltine........................
07/17/2013 4:26 PM
Just a guess, but ZSC is used as a valve travel limit switch quite frequently and there is usually an NO or NC associated with the valve, often posted on the P&ID nearly on top of each other. Did the op get two denotations run together and drop the O or C?
The other less likely scenario is the valve is valve N so the limit switch would be NZSC?
Good Answers: 176
07/15/2013 11:11 PM
The ISA-5.1-1984 (R1992), Formerly ANSI/ISA-5.1-1984 (R1992) standard's table 2 is one page, "Typical Letter Combinations"
Unfortunately, copyright restrictions prohibit its reproduction.
Register to Reply 7 comments
bigg (1); Iris (1); lyn (3); Phys (1); Tornado (1)
