Previous in Forum: Difference Between Normal Junction Box & Flameproof Junction Box   Next in Forum: Level Switch Displacer Chamber's Vent
Ultrasonic Transducer Question
07/22/2013 9:18 AM
I need ultrasonic transducer which can take 1Kg load, @1Kw with frequency generator for project work which will use under water. If you have any idea @ this then please suggest me.
Re: ultrasonic
07/22/2013 9:25 AM
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
Re: Ultrasonic Transducer Question
07/23/2013 10:03 AM
What do you mean exactly by "1 kg load" on an ultrasonic transducer? What is your intended application? 1 kilowatt is a lot of power for an ultrasonic sensor -- I am assuming you are intending to use this for ultrasonic cleaning or some purpose other than measurement (instrumentation).
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Register to Reply 2 comments
