Previous in Forum: 5 Ton Split AC Gas/Electric   Next in Forum: Which Bolts are the Strongest
Nozzle Failing Under UG 45
07/22/2013 8:09 PM
I am designing a hygienic vessel. For which requirement of pipe is as per DIN 11850.
Design pressure of vessel is 1.65 bar. Total Height is 10 m. Vessel wall thickness is 6 mm.
As per DIN11850, maximum pipe thickness available is 2 mm. Available pipe sizes are DN10 to DN150.
While designing nozzles, these pipes are failing under clause of UG 45 due to 2 mm thickness.
I checked with adding pad plate but still it is not passing.
The min. required thickness of nozzle is more than 2 mm.
Solution for this problem will be highly appreciated.
Can we exempt UG 45 ?
Re: Nozzle Failing Under UG 45
07/22/2013 8:32 PM
I'll grant you an exemption for UG 45.
Use of this stamp is subject to charges and penalties for fraudulant use.
07/22/2013 10:27 PM
07/23/2013 12:02 AM
Maybe you could make the nozzle out of "normal" pipe/tube, and then continue with the thin-wall DIN 11850 pipe/tube.
Register to Reply 3 comments
lyn (1); SolarEagle (1); Tornado (1)
