Previous in Forum: ID Fan Shaft Diameter   Next in Forum: CSA Z662-11 Clause and Clause 4
12 comments
Front vs Rear Track
07/27/2013 10:42 AM
Regarding the front and rear vehicle track of car , Which one would be better
Front track more than rear (or) Rear track more than Front track
i have seen different car specs with Swift's rear track being wider than the front and honda's front more wider than rear ?
What are the consequences of above two
Re: Front vs rear track
07/27/2013 10:55 AM
What do you think they are?
Anyone wanting to be a "Formula 1 engineer" should already know all of this.
Why not do a little research and come back here when you can intelligently discuss the topic.
Surly, you would have an opinion about the implications of the subject.
In what context do you mean, "better"?
Back to you.
Re: Front vs Rear Track
07/27/2013 1:37 PM
It has to do with engineering stability into the handling of the vehicle....When you are pushing a car into a corner you want all the wheels to give at the same time....so if the weight is distributed other than 50/50 you can compensate with track width or tire width....The track is measured wheel center to center, so if you have a wider tire on the back or front, it might just appear to be a wider track....that is of course if we are discussing an automobile used on the road in a normal fashion....
Good Answers: 48
07/27/2013 3:00 PM
Impossible to answer.
Too many variables.
Too many things more important that track.
Good Answers: 203
07/28/2013 1:38 AM
Get a motorcycle, moped, tricycle, motorcycle with side car, unicycle or a bicycle. Consequences of less than 4 wheels is you don't have to worry about the track!
Good Luck, Old Salt
07/28/2013 2:18 AM
Motorcycles have different size wheels and different widths of tyres allong with different tyre compositions to help them to drop in when cornering, manafacture specifications usually are followed by tyre insallers very stringently .
Luck definately comes and goes----- I had a win today,,,,I saw the sun rise.
Good Answers: 203
07/28/2013 9:51 AM
Excellent answer for the motorcycles! For the OP's benefit, what about the moped, tricycle, motorcycle with side car, unicycle or a bicycle? Never had to take a tricycle to have it's tires tuned or worry about the track of it's drive axle with only one wheel. Likewise for the unicycle.
Good Luck, Old Salt
07/28/2013 1:53 AM
This does not even deserve an answer.
"Real Bass Players" do not use picks
07/28/2013 7:46 AM
then y did you reply ?? damn
07/28/2013 10:37 AM
Do your own homework!
Then you won't be bothered by people who think you are lazy.
07/28/2013 3:39 AM
Cars that have front engines, gearboxes and front-wheel drive hardly need rear wheels, except to stop them scraping on the ground!
My old Citroen DS21 had visibly narrower rear track. Some hot Porsches appear to have narrower front track (but might be just wider rear wheels).
Roll stability is most affected by the track at the heavy end.
Good Answers: 21
07/29/2013 9:08 AM
Sensibly, the wider track is usually more useful for traction on the drive wheels.
I doubt your facts................ The 5 models of Swift I looked at share only three sizes between them, and they are uniform (Front = Back in all cases).
The sizes are : 175/65 R16; 185/55 R16; 195/50 R16
Good Answers: 54
08/01/2013 9:42 PM
In regard to why the Swift and Honda use different front/rear tracks, it has to do with engineering and costs. Honda tries to engineer their cars to be safe, reliable, good driving and efficient. Suzuki on the other hand is probably looking at cost savings over some of the criteria Honda looks at.
If you push the tires out wide, you increase the stress on the suspension parts and the chassis. Since there is more weight on the front end of front wheel drive cars, there will be more stress in pushing the wheels further out vs pushing the back wheels out. So Suzuki can cut corners by keeping the front narrower than the rear, hence less stress of on the suspension and chassis of the car = cheaper to produce. Honda isn't as cost conscious as Suzuki, so they can put more money into a better chassis/suspension and push the front wheels out further than the rears.
I know Honda pretty well and I think they do a phenomenal job engineering their cars. If there's a way to improve the car, Honda has done it (or is working on it).
Register to Reply 12 comments
Autobroker (1); harsha_iit (1); Hilton (1); Holzfeller (1); Jimh77 (1); lyn (2); Maurie (1); NeilA (1); old salt (2); SolarEagle (1)
