Previous in Forum: Simple Pump Start Stop Logic   Next in Forum: Critical Pressure of a Butterfly Motor Operated Valve
PLC and DCS Hardwired Signals
07/30/2013 7:02 AM
Do anybody have any literature or related documents of a plant that has plc to dcs hardwired and soft signal exchange list?
I am new to these things .Please help
Thanks in advance.
Pathfinder Tags: plc & dcs
Re: plc and dcs hardwired signals
07/30/2013 7:24 AM
Contact the equipment manufacturer directly to determine the way that soft signals are exchanged, for the protocol varies from make to make.
Look at the project-specific I/O lists and respective schematic drawings to determine the hard signals.
Good Answers: 69
Re: PLC and DCS Hardwired Signals
07/30/2013 8:45 AM
If you are new to this, order a small PLC and a modest HMI to build a practice application, that will make clear for you the concepts of hardwired and soft signals, and what memory mapping is, meanwhile read this document.
Regards
Register to Reply 3 comments
lyn (1); PWSlack (1); Yahlasit (1)
