Previous in Forum: CO2 Tunnel   Next in Forum: Plating With Rhodium
Cracking Problem in IS 2062 B After Bending at Customer Site.
07/31/2013 6:31 AM
we have supplied the material grade IS2062 B to our customer.Customer complaints the cracking problem after bending the material.As per standard the material is OK in Bend test as per our test record. Material size - 2.8x1250x2500. Pl suggest the solution for this case.
Re: cracking problem in IS 2062 B after bending at customer site.
07/31/2013 6:50 AM
How is the sheet manufactured? If it is rolled it will have a grain direction, maybe the customer needs to heat treat it, or orientate the material in a specific direction before bending?
Does the material spec include any heat treatment or is it just a chemical composition spec?
07/31/2013 7:12 AM
*sheet manufacturing-slab cast & rolled
*customer-does not heat treat material only cold working & forming.
*spec -no heat treatment required only chemical composition spec.
Re: Cracking Problem in IS 2062 B After Bending at Customer Site.
07/31/2013 12:35 PM
I've asked this question far too much, with mostly silence in return.
I'm guessing that you are not the manufacturer of the steel.
So, WHAT DOES THE MANUFACTURER OF THE MATERIAL HAVE TO SAY ABOUT THIS???
Not much here to go on. Maybe you could send us a sample.
The cat's in England and I'm in the USA.
Get your supplier involved, now.
Good Answers: 25
08/01/2013 6:19 AM
It seems M.S plate is not annealed properly. IS2062 is for tested quality steel mostly used for fabrication. If it is cracking while bending then it should be tested again. Results should be shown to steel mill. Please carryout physical and chemical test and check up if it is as per specification.
Hobbies - CNC - New Member
08/01/2013 10:27 AM
  1. Is your bend and the customers bending processes the same?
  2. Are the bends the same shape?
  3. Radius? Sharp?
  4. What is the Carbon content?
  5. Are the materials from the same mill run?
  6. Do you have the Mill Certifications?
  7. With a little more information we may be able to assist you in finding a solution
  8. GradeC% Max.Mn% Max.S% Max.P% Max.Si% Max.C.E.% Max.
    A0.231.500.0500.0500.400.42
    B0.221.500.0450.0450.400.41
    C0.201.500.0400.0400.400.39
lyn (1); Original_Macgyver (1); pmdhabarde22 (1); suresh sharma (1); user-deleted-1105 (1)
