Previous in Forum: Powerplant Question   Next in Forum: User Question- Best Pump for Lifting Lake Water to Camp
HRSG Preservation with N2
08/01/2013 10:55 AM
Dear CR4 members: Please advise regarding filling HRSG tubes with nitrogen gas: 1. What is min nitrogen gas purity recommended? 2. What is the max acceptable oxygen %?
Re: HRSG Preservation with N2
08/01/2013 11:01 AM
Good Answers: 104
08/01/2013 2:10 PM
Google 'boiler preservation' or 'boiler preservation procedure'. If you are doing dry preservation, nitrogen/oxygen content is not as important as dew-point/condensation.
Don't forget the superheater, economizer, etc.
08/01/2013 3:33 PM
This sort of stuff ought to be in the User Manual supplied with it. If it isn't, or the manual is missing, then it's time to contact the boiler manufacturer directly; pick up the phone and get dialling.
08/01/2013 11:53 PM
It does need to be dry first, ideally a dewpoint of -20 Deg C.
You'll find it hard to get nitrogen with less than 99% purity out of a bottle or from vapourised liquid. if your running a generator (membrane or PSA) 98% purity will be fine. Oxygen content of less than 2% by volume should be your target IMHO.
Want to know how much you will need, tell me the volume and the pressure rating and I'll show you the cycle purge calcs, much more effecient than just displacing for anything that isnt just simple pipe.
08/02/2013 8:44 AM
Dear "HeHound", many thanks for your comments. Total volume required to fill the HRSG is about 157 cubic meters at 5 psig (0.35 barg). I will be grateful if you can show me the calculation for how many cylinders will be used and also what extra margin of volume has to be provided to account for leakages assuming leakage rate of 1 cu meter per hour.
Regards
08/02/2013 9:01 AM
Your less expensive application will most likely be a liquid N2 dewar with 150 liter of LN2 (I think this is the standard size, as I recall), and a small heat exchanger to cover the heat input of vaporization. Direct sunlight on this or just hot desert air should be sufficient. Depending on local humidity, you might do just as well by simply blowing hot dry air through the HRSG once drained, and once the metal is dry, you will have slowed corrosion to the flow of ashpalt in Antarctica.
Register to Reply 6 comments
bigg (1); HeHound (1); James Stewart (1); lyn (1); power engine (1); PWSlack (1)
