Previous in Forum: User Question- Best Pump for Lifting Lake Water to Camp   Next in Forum: SHACKLES...Which One is the Strongest
Fillet Weld on a Socket Weld End Flange Calculations
08/01/2013 12:55 PM
I am working right now on new pressure system, for some reason the flanges ordered are socket weld flanges (dont know why) but we cannot return them anymore as they were ordered from a company that is no longer in business.
Long story short, I have never had to mess with fillet welds, in the past we have always used butt-welds. So I am having to scratch my head a little to get some stuff on paper.
I have looked at ASME B31.3 paragraph 328 and figure 328.5.2B, and the "fillet weld size" that I am getting is 0.25in
Is this all I am required to do to "meet" the Code requirements?
I want to run a stress calc on this, but I can only find some IIW and ISO equations for flat fillet welds on plates, those methods ignore the shear stress parallel to the weld axis, however since I am dealing with a circular weld around the flange this would turn into more of a tangential stress ala hoop stress.
I was looking specifically at this:
http://www.gowelding.com/calcs/c2.html
http://www.roymech.co.uk/Useful_Tables/Form/Weld_strength.html
Any suggestions, I think its been too long of a week and I am look far too hard at this.
Thank you
Pathfinder Tags: fillet flange socket weld stress weld
Re: Fillet Weld on a Socket Weld End Flange Calculations
08/01/2013 4:01 PM
My advice for you is to pay someone with adequate knowledge of welding and your specifications to solve your problem.
What does the specification say.
Where is the pressure system located?
Good Answers: 137
08/01/2013 6:52 PM
Why do you need to bother? For tangential stress, if the pipe itself is OK, so is the part of it inside the flange, and the weld + flange gives additional area to take the load.
For longitudinal stress, you can work out the load based on pressure and pipe OD (worst case, assuming the pipe is not restrained elsewhere). It shouldn't be hard to estimate the weld area that takes the force (thickness x circumference) to get the stress. Most unlikely the stress will turn out excessive. Helped by fact that based on the pipe wall only, longitudinal stress = 0.5 x tangential stress.
Popular Science - Weaponology - New Member Canada - Member -
Location: In the sticks of the Central Kootenays, BC, Canada
08/02/2013 12:50 AM
If you (and your plant guys) are not familiar with socket weld fittings and their treatment, I should comment about a detail we learned by seat of the pants experience with socket welds. Make sure your tradesmen don't bottom out the pipe in the socket before they weld. It needs to have a small clearance to allow for expansion of the pipe during the heating from the welding. The pipe cannot move since the weld is holding it and the bottom of the socket won't move either. The weld may crack from this condition.
We learned this from bitter experience while welding small-diameter hydraulic lines with socket weld fittings. My memory is a bit vague on the details, but I believe that there may be a commercial item available that is inserted before welding to make the spacing procedure a straightforward detail to a tradesman.
Hope this helps,
Jon.
Good Answers: 203
08/02/2013 11:24 PM
I used to use a very short length of the same diameter pipe to accommodate this recessing of the pipe before welding. The length of this insert was equal to the length that I wanted the pipe recessed. i.e. for welding 2" pipe with a recess of 1/2" inside the flange, use a piece of 2" pipe 1/2" long. Insert this in the flange and rest the flange with this ring in it on the welding table or other surface. Run a couple of long tacks or stringers of the outer weld and then remove the ring. Complete your outside and inside welds and you have a perfect recess. I would make these rings on a good power hacksaw or band saw every time I had the chance for one of a size I didn't have. Different recesses too. Organized them on one of those "giant safety pins".
Many welders and pipe fitters caught onto the idea and made themselves a set!
Good Luck, Old Salt
Good Answers: 38
08/02/2013 7:16 AM
Try to become at least a bit familiar with the Codes and Standards that govern your piping installation.
ASME B31.1 allows piping system design, construction and installation using full penetration butt welds and PROPERLY SIZED FILLET WELDS without calculation of individual weld strengths.
Of course, a qualified weld procedure and properly rated pipe flange is also required to meet the code.
08/05/2013 9:59 AM
thanks everyone for the input
@lyn
we cannot hire someone from outside because our contract makes it very hard, we do have certified/qualified welders on site, I have talked to them and while their experience/training tells them what to do, the "why" that I need to document is missing.
@codemaster
I was thinking the same thing about the hoop stress, but our pressure systems guru here sometimes can be over-conservative and make us jump through alot of hoops before he is satisfied. I just wanted to put a number to it so he cant ask for it later
@MJcronin
B31.3 is what the base system was originally designed to meet. I think the 328 paragraph in 31.3 allows the same, but as I am sure you are aware, the code rarely just comes out and says things and my interpretations may differ from what our pressure systems engineer reads into it
Register to Reply 6 comments
Codemaster (1); Korichnevijgigant (1); lyn (1); MJCronin (1); old salt (1); sawmilleng (1)
