Previous in Forum: Paralleling Generators   Next in Forum: Alignment of Turbine to a Generator
24 comments
My Electric Generator Won't Start
08/03/2013 8:49 AM
KVA IS 250. VOLTAGE IS 400.HZ IS 50 MANUFACTURED BY VOLVO PENTA. MODEL. IS TAD734GE PLEASE HELP WE ARE IN DARKNESS. AND I AM RESPONSIBLE.I THINK WHAT IM LOOKING FOR IS THE ELECTRICAL WIRING DRAWING OF THIS EQUIPMENT. I APPRECIATE ANY USEFUL INFORMATION
Yea, Machines we are,you are one of us.Or aint you
Pathfinder Tags: TAD734GE VOLVO PENTA
Good Answers: 181
Re: MY ELECTRIC GENERATOR WONT START
08/03/2013 9:03 AM
Stop SHOUTING!
08/03/2013 10:48 AM
Maybe since it's dark where he is at so he needed to write big?
08/03/2013 9:07 AM
Go to the Volvo website and download it.
"Won't start" could mean any of 50 different things.
08/03/2013 9:15 AM
I've been to Volvo site,I could not find the wiring drawing Please help is still needed.thanks
08/03/2013 12:19 PM
The problem is e-mail and websites. Wrong media for problem-solving!
  • Get on the phone to Volvo. Be a total pest with them. Irritate them until what is needed arrives. Talk to a technical specialist there, who may be able to diagnose the problem over the phone.
  • If that doesn't work, use the phone to arrange for the local technical specialist to call in, diagnose, fault-find and advise. What is needed is something faster.
  • Surely there is a planned preventative maintenance schedule on this thing? If not, then use the phone to set one up.
Now that is "responsibility" - the ability to respond to the problem at hand.
08/03/2013 11:11 AM
First, calm down. Don't panic. You need to think clearly or you will not fix this.
Second, this is the wrong site to get machine specific support. We can help you in only a generic fashion. Volvo support is the ideal place to get this assistance.
Third, be concise and methodical in your explanation of what is or is not happening. Unless you can get support to arrive at your location, your senses translated through your words are the only way support can help you. "It doesn't run" and "we are in darkness" is useless diagnostic information. Identify and clearly communicate with support (us or a remote Volvo technician) what does and does not work and at what point does the failure happen. Does the engine run but the generator not produce electricity? Does the electric start try but fail to spin the engine?
Many times a wiring diagram is not really needed to fix a previously working system. Inspection of previously working wiring will most of the time identify the root of an electrical problem. Look for bad connections, broken wires, chaffed insulation, corrosion, etc. Now if you find that a rodent has chewed through multiple wires in a harness and you find that the wires are not color coded then you will need a wiring document.
08/03/2013 12:10 PM
"First, calm down. Don't panic. You need to think clearly or you will not fix this."
GA Good Advice!
08/03/2013 12:50 PM
Have checked, no visible wire breaks, starter motor not responding from digital control panel which says I should check ECU. Starter motor cranks engine on direct test but engine will not combustion running. Without the wiring diagram,I am becoming lost in this darkness .This location is so inaccessible. I need WIRING DIAGRAM link or VOLVO PENTA TAD734GE expert I can't seem to get any.please help
Good Answers: 88
Re: My Electric Generator Won't Start
08/03/2013 5:36 PM
If you have done everything stated in the OPERATOR MANUAL diagnostics, and no joy, it's time to get in contact with an expert. "Responsible" means exactly that and wiring diagram even if you had it, on a "won't start" expertise, can't go far. S.M.
08/03/2013 5:50 PM
Thanks. Im still on the search for a solution information
Good Answers: 176
08/03/2013 6:19 PM
Have you gone through the basic troubleshooting steps in the operations manual, page 49 (pdf), available here?
http://www.voltaprima.com/uploads/files/support/Operators_Manual_TAD734GE.pdf
08/05/2013 4:31 AM
Iris, I've sent a mail to this link's service email address, I was replied in bad English and I have not been given the WIRING DIAGRAM. Please I can include your correspondence email address if you are willing to assist me. Thanks
Good Answers: 140
08/03/2013 10:54 PM
Do you have fuel?
08/03/2013 11:50 PM
Thanks and yes I have gone through the operators maintenance manual and checks. And yes I have fuel. What I am facing here is loss of ECU control command WIRING DIAGRAM please Thank you
Good Answers: 140
08/04/2013 1:38 PM
Looks like you have to buy it.
Click Here
08/04/2013 1:44 PM
I hope you would have interchanged battery unit - from other gen. unit or for Ah verification .
08/04/2013 2:00 PM
At this point , I don't mind buying it (source?) .Yes I have checked the batteries Ah (current) wiring drawing please. Thank you
Good Answers: 181
08/04/2013 2:21 PM
If you read, you have been given the link.
08/05/2013 4:42 AM
Thanks all, I'm in an email correspondence with 'the link ' but I have not got the WIRING DIAGRAM yet.any other corresponding solution to my woe is welcome WIRING DIAGRAM please
08/11/2013 9:18 AM
http://www.magnumenergy.com/service/genwiringdiagrams.htm
If you expect loss of control command - from software side ; program needs to be uploaded .
If from hardware - dry soldering / loose connection or replacement of cable based on DMM's continuity tester feedback ( w.r.t. Ohmic value between points ) would be of our concern . In this case , similar gen. set if with yourselves - will be much easier for comparing the values ; w/o drawings . 5V DC if used by them - that should exist .
Other drawings will also give reliable feedbacks . Apart from this , we always don't need drawings . I will prefer to give references of earlier discussions on similar topics in this Forum .
08/19/2013 6:35 AM
Thanks to CR4, I have the wiring diagram now, from what is before me now, I am dealing with a CAN J1939-75 diagnosis. This engine is equipped with a CAN bus communication system.The control panel is MICS TELYS and the ECU is tad734ge (volvo penta/powertrain) I have contacted volvo penta representative. and their quote is prohibitive due to their proximity.The engine is receiving mechanical. attention by an experienced mechanic due to water ingress from existing poorly constructed exhaust routing. Present control panel faults reads; "Engine CAN BUS" and "CAN BUS 1" When the mechanic is done, I hope to eliminate this "CANbus" issue, but how? I don't yet
09/05/2013 12:10 PM
CAN Bus communication is claimed for its efficiency even if its one of the terminals come into contact with Ground or Supply voltage .
Perhaps , loose connection { no contiuity } or both are in contact with ! - could also be a cause . You may check for its voltage availability as well .
09/10/2013 9:53 AM
Sure Sivaa. And thanks, we have resorted to alternative electric source. The CANbus is responding with associated OEM interconnections with all fault codes eliminated. The pending issue before me now is STUCK MECHANICAL PISTONS due to water ingress. I'm working with a mechanic now to free the ringed stuck pistons.I shall celebrate with CR4 here on success
09/11/2013 12:03 PM
So , you now work for stand-by source . It is good to have such an alternative . Regards .
Register to Reply 24 comments
Iris (1); Kilowatt0 (1); lyn (1); North of 60 (2); PWSlack (1); redfred (1); SimpleMind (1); sivaa (4); tcmtech (1); TonyS (2); Ukeje (9)
