Previous in Forum: Cause Of Sudden Jamming Of Steam Turbine Rotor At Barring Speed   Next in Forum: Water Pump "Explosion"
15 comments
Need Info for a Integral Hydraulik Unit
08/07/2013 11:20 AM
I am looking for a parts diagram and flow diagram for a Integral Hydraulik unit.
Typ: 233.007 it is a standalone unit used on a napkin converting machine by Ser O Tec
I looked all over the web and could not find any info on it.
Thanks for any help
Harvey
Re: Need info for a Integral Hydraulik unit.
08/07/2013 11:22 AM
Here is picture of unit.
08/07/2013 11:27 AM
I would contact the company, or distributor...
http://www.servotec.de/
08/07/2013 2:13 PM
Tried that no luck so far
08/07/2013 5:07 PM
This unit looks like it was built to custom specs, you should have the paperwork on file, or the original purchaser....there had to be a design submitted for approval...Do you know who originally ordered the unit?
Re: Need Info for a Integral Hydraulik Unit
08/07/2013 12:03 PM
RTFM: "Ring the ...... manufacturer" or "read the ......manual".
08/07/2013 2:16 PM
This pump may not even be made by Serv o tec.
But with no information to go on, it's impossible to tell.
Garbage in....................................Nothing out
Call the manufacturer.
08/07/2013 3:09 PM
No the pump is not made by Serv O Tec it is Integral Hydraulik and they are in Germany and I did not get a response from them. I would not waste your time if I did not do my homework. I have a machine down and was just looking for help.
Not a question of Garbage in.......................Nothing out
08/07/2013 3:29 PM
People DO waste our time here, every day. Others, such as yourself prefer to play 20 questions.
We've established that it is made by Integral Hydraulik .
Now, if we only knew the part/model number of the specific unit, someone here might be able to help you.
08/07/2013 3:44 PM
Lyn
The modle # was in orginal post
Typ: 233.007
Thanks
08/07/2013 3:47 PM
Saw that.
The format threw me.
Engineering Fields - Aerospace Engineering - New Member
08/07/2013 3:23 PM
Cowboy : Mark Steele
CR4 ADMIN - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
If your macine is down , perhaps I can assist you in gaining spec sheets from
manufacturer , or parts from aftermarket sources .
( Aeroengineer ) Canada
CR4 ADMIN - phone number removed
08/07/2013 4:20 PM
Thanks Lyn
Yea I been there and tried that. called and emailed
Thanks for tring
08/08/2013 3:32 AM
May I suggest you drain the tank and dismount the electric motor. You will probably find a close coupled hydraulic pump at the end of the motor ( in the tank ). This pump may even be made in USA!
Good Answers: 266
08/08/2013 7:30 AM
Generally these units are all the same. Whats the problem?
08/08/2013 8:56 AM
Thanks for all the interest and willingness to help.
I got the system up and running. The check valve inside was bypassing slowly and causing the unit to cycle to often. Ran the unit in bypass and flushed whatever it was out. I could still use the diagrams if anyone comes across them. (don't think Germany will get back to me).
Again thanks to CR4 for it's professional input.
Cowboy
Register to Reply 15 comments
JIMRAT (1); justthecowboy (6); lyn (3); ozzb (1); PWSlack (1); SolarEagle (2); Steele113 (1)
