Previous in Forum: Two Hole Rule For Flange   Next in Forum: Need Info for a Integral Hydraulik Unit
Cause Of Sudden Jamming Of Steam Turbine Rotor At Barring Speed
08/07/2013 7:35 AM
we have two 250 mw steam turbine (BHEL make) unit. recently we are facing lot of trouble related to jamming of rotor when machine at barring gear. we have hydraulic motor operated turning gear arrangement at front pedestal. after normal shut down m/c put into barring gear automatically at 56 rpm. after 10 hrs when m/c is ready to roll (vacuum pulled and hp-lp bypass charged condition) we found rotor speed slowly decreased to zero. then hand barring started and continue till barring came again at hp shaft and casing temperature 290 deg C almost 48 hrs. please look into the matter and put your suggestion to overcome the problem. further more this situation happend three times in last one year.
Re: Cause of sudden jamming of steam turbine rotor at barring speed
08/07/2013 7:38 AM
"Foreign contaminant!"
Good Answers: 444
Re: Cause Of Sudden Jamming Of Steam Turbine Rotor At Barring Speed
08/07/2013 1:43 PM
Until you perform a complete internal inspection of both the turbine and the generator (they both have rotors) you have no way of telling where the binding takes place. There are many causes of this type of problem, but if it was working ok until the last maintenance shutdown then something was not done properly when the machine was reassembled.
Poor shaft/bearing alignment and/or bearing lubrication is indicated. If this occurs on both machines then it is most likely that whoever performed the last realignment followed the cold alignment procedures when the machine had not been idle long enough or followed the hot alignment procedures when the machine was at the wrong temperature.
You need to inspect everything related to the lube oil, barring gear, and shaft/bearing alignment. This not an experiment for the inexperienced, call the factory and pay for expert guidance.
Good Answers: 104
08/07/2013 4:55 PM
Is this you again? http://cr4.globalspec.com/thread/62479#comment653427
Why are anonymous posts allowed?
08/08/2013 3:19 AM
...then the cause is a failure to follow the advice in the earlier thread.
09/09/2014 10:59 AM
It is possible,
1. that one blade might have dislodged from its position and trapped in the gap and got struck up.
2. the bearing might have got melted and seized.
Pl. inform this forum what was the problem and how sorted out.
DHAYANANDHAN.S
bigg (1); dhayanandhan (1); PWSlack (2); RAMConsult (1)
