Previous in Forum: IMEI Number Tracing   Next in Forum: Using Iphone 4s as a Modem
Check On The Below Simulation - Bubba Oscillator ||PROTEUS
08/21/2013 12:04 AM
The following circuit is not running in simulation mode in Proteus ,
can anyone assist me on what should be done ?.......
Frank - Catch my statement if you can.
Pathfinder Tags: bubba oscillator proteus
Re: Check On The Below Simulation - Bubba Oscillator ||PROTEUS
08/21/2013 9:31 AM
Lose those awful sun glasses. Maybe you just can't see how to search for one of the 23,500 results.
08/21/2013 9:59 AM
oh iyn
ur one shameless
if u dont want to answer or not interseted keep ur ass tight and shut
08/21/2013 10:08 AM
Did you search for the answer, as I suggested?
Search for "Bubba Oscillator".
Finding Information on the Internet: Table of Contents
Your post is unreadable, the figure and text is indecipherable.
08/21/2013 11:37 PM
Hi Frank,
The problem is that you are missing the phase shift resistor that should be inserted between R1 and C1. Also usually the Phase shift should be set for 45 degrees for each stage so each of the phase shift resistors and each of the phase shift capacitors should have the same value. Also the gain should be = to -4 in the first stage, which I think you got right. (It is hard to read the schematic.)
Hope this helps,
Dan A
MSEE
08/21/2013 10:57 AM
...and the approach taken is deplorable.
08/22/2013 4:00 AM
Dan
Thanks I Got it ...
08/22/2013 11:49 AM
Looks like a government design to me...
Register to Reply 7 comments
Dan A (1); frankcorners (2); lrsheldon (1); lyn (2); PWSlack (1)
