Previous in Forum: Load Sizing for Air Conditioning   Next in Forum: UPS P.F 0.9
9 comments
Woodward LSM Problem
08/25/2013 8:02 AM
hai guys
i have a probelm with woodward LSM modulde ie,my vessel have 3 no caterpillar generator.when no.1 & no:2 generator in load sharing it is working fine.but if we start the no.3 generator (breaker is open )other two become unstable.when removing the loadsharing line from no.3 generator LSM then no.1&2 working ok.
if no.3 is with the any one of the other generator then also hunting is happening.no variation in engine speed.
can anybody give good suggestion for solving the same
Re: Woodward LSM Problem
08/25/2013 9:57 AM
Could be moon phase.
Maybe a broken framus.
I think I see a problem with the #3 genset fuel supply. From here, it is really hard to tell.
Try asking these guys: LSM - Woodward
Reply Score 1 for Off Topic
08/25/2013 10:47 PM
I had a similar problem one time with 2 Cat generators.and it turned out to be a bad speed sensor on the incoming gen.
"Hope for the best,expect the worse,and take whatever comes!"
08/25/2013 10:56 PM
Bur in this caise their is no speed sensor to LSM . This problem is happening in ino.3 gen deal running/on load also.
08/25/2013 11:25 PM
"can anybody give good suggestion for solving the same"
Call a service tech and have #3 genset fixed.
Yes, it will cost money.
Don't waste time hoping that it can be fixed free of charge.
Good Answers: 181
08/25/2013 11:29 PM
What happens if you run sets 1 & 3 or 2 & 3?
08/25/2013 11:48 PM
A generic solution with plc is far superior to vendor dependent solution in the long run.Any one can locate and solve.Solid example.
Better not count the cent if the risk is many many dollars.
Good Answers: 34
08/26/2013 1:28 AM
First ensure that the cable used for equalising line between various LSM modules is good quality shielded cable with twisted pairs.
2nd Ensure that screen of all shielded wires are earthed BUT only at one end.
3rd ensure that shielded cable is not laid in the trunking in parallel with any AC power cable.
If problem exists, use twisted pairs for 24V DC power supply to LSMs of each machine.
If nothing of above works do following:
For LSM to start sharing load, Terminals 13 and 14 are shorted via DG ACB contact. To sort out the cause of problem, instead of disconnecting equalizing lines from LSM of DG 3 open 13 and 14, if the problem of instability of DG 1 and 2 disappears, check the cable and auxiliary contact connected across 13 and 14 for possible short or poor insulation resistance between the cores of cable or across the contact. This is a marine application and most probobly any tracking across the contacts could be the reason of problem. Though the chances are remote as I have noticed that Panels are located in a bottom portion of the ship with sealed doors and ventilated room - but in case the ship was out for some long maintenace and doors were left opened for long period in the docks, possibility of salt moisture and tracking can not be ruled out.
Best or luck.
08/26/2013 3:39 PM
What was the outcome of the telephone call with the equipment manufacturer's Technical Helpline?
08/26/2013 3:44 PM
No instant gratification that way.
And, they might want to charge for their valuable time.
Jans (1); lyn (3); powersolutionsFBD (1); presanthn (1); PWSlack (1); skipperj (1); TonyS (1)
