Previous in Forum: Crane Hook Approach   Next in Forum: 304LN Grade in Stainless Steel
Location: pipe line project - KSA ( welding inspector - CSWIP 3.1)
Branch Reinforcement (Carbon Steel Pipe)
08/26/2013 7:15 AM
in our project ( pipe line project )we havt to fabricate a reduce Tee ( 72" to 32") my qustion is are we need a reinforcement plate in the hole that we made or not???
Is there any code or specification explain this situation?
Re: Branch reinforcement (carbon steel pipe)
08/26/2013 8:33 AM
Insufficient information. Needed are:
What wall thickness of each pipe?
What type of steel?
What internal pressure?
What local codes apply?
Almost surely you will need reinforcement, unless one or both pipes have quite a bit of surplus thickness.
08/26/2013 8:52 AM
Steel is C.S api 5l x52 internal pressure is 10 bars Both pipe is about 9.54 mm applied code is awwa m11
08/26/2013 9:06 AM
I haven't done calculations, but it doesn't look as though you have much (if any) surplus wall thickness. That almost definitely will require a reinforcement pad. If AWWA doesn't have a calculation method for this, API probably does. Also ASME 31.x would have this (I forget which subchapter x applies to your situation).
Good Answers: 104
08/26/2013 10:51 AM
I think AWWA M11 contains reinforcement requirements. If not, maybe AWWA C200 or C208. Since this is an AWWA job, I wouldn't use B31.1 or B31.3 unless the client agrees to deviate.
Good Answers: 38
Re: Branch Reinforcement (Carbon Steel Pipe)
08/27/2013 7:05 AM
Are you constructing a pipeline without any governing code or specification ?
How do you know if your materials are acceptable ?
How do you know if your welding is acceptable ?
At 10 bar design pressure, this is a serious pipeline.
Rules for area reinforcement of fabricated tees have been around for 50 years.
Acceptable methods can be found in ASME B31.1/B31.3..... but you must know your code of record
bigg (1); galal_elden (1); MJCronin (1); Tornado (2)
