Previous in Forum: Branch Reinforcement (Carbon Steel Pipe)   Next in Forum: Elastic Deformation
11 comments
304LN Grade in Stainless Steel
08/26/2013 1:28 PM
In ASTM A312 I saw 304, 304L and 304LN grades where N stands for nitrogen . . What benifit you get for using Nitrogen in L grade steel
United States - Member - New Member Engineering Fields - Instrumentation Engineering - Popular Science - Cosmology - Beam me up Scotty!
Re: 304LN grade in Stainless steel
08/26/2013 2:13 PM
ERRR!
You might have tried Google for this one. I Used your own words in the Search and came up with this.
quote from the following article.
http://www.keytometals.com/page.aspx?ID=CheckArticle&site=kts&LN=EN&NM=202
All steels contain some nitrogen which is effective in improving the mechanical and corrosion properties of steels if it remains in solid solution or precipitates as very fine and coherent nitrides. When nitrogen is added to austenitic steels it can simultaneously improve fatigue life, strength, work hardening rate, wear and localized corrosion resistance.
High nitrogen martensitic stainless steels show improved resistance to localized corrosion (pitting, crevice and intergranular corrosion) over their carbon containing counterparts. Because of this, the high nitrogen steels are being considered a new promising class of engineering materials.
Stainless steel also contains Nickle!!!
Pitting Resistance Equivalent Number (PREN) is a measurement of the corrosion resistance of stainless steel containing nickel. Exact testing procedures are specified in the ASTM G48 standard.[1] In general: the higher PREN-value is, the more corrosion resistant the steel is.
"Experience: that most brutal of teachers. but you learn, my God do you learn." - C.S. Lewis
08/26/2013 7:31 PM
WTH is "nickle"?
Good Answers: 141
08/26/2013 8:04 PM
Ni
Plenty of room here
08/26/2013 8:39 PM
Got a nickle in my pocket Nex to me kees. Good catch! I should use spell check more often! Nickel, Ni, atomic # 28
08/27/2013 8:18 AM
who is "Nex" and what is "kees"???
08/27/2013 3:16 PM
Really?
09/02/2013 2:39 AM
Sure!
08/27/2013 10:29 AM
Yep, nickle is the cost driver in stainless steel.
08/27/2013 10:54 AM
What about chromium?
And what's this "nickle", anyway?
08/27/2013 11:15 AM
Nickel.
Nickel is what the metal sales people look at when predicting the cost of stainless steel to going up or down.
Re: 304LN Grade in Stainless Steel
08/27/2013 6:02 PM
304LN Datasheet
The nitrogen provides improved yield and tensile strength over 304L.
Register to Reply 11 comments
1tech (3); Doorman (1); dvmdsc (1); IdeaSmith (2); Janissaries (2); Tornado (2)
