Previous in Forum: Induction Furnace Electrical for Melting   Next in Forum: Phase
18 comments
No Load Current of Motors & Pumps
08/30/2013 12:09 AM
I have got induction motors & monoblock pumps in our company.i want to do a study on the no load current of motors.the motor which got rewinded 4-5 times certainally its no load current increases from its standard.due to this its efficiency reduces.if i got a table of no load current according to its hp .then i can be able to do my exercise.can any one help where i can get this data or any other view on this pl. Suggest.
Re: no load current of motors & pumps
08/30/2013 12:42 AM
You need to contact the original motor manufacturer. There has been significant improvement in motor efficiency in recent years and some manufacturers have literally left the others in the dust.
You will also need to specify whethere the pumps are coupled to the motors during the test or the motors are free standing since the resistance of the pump will influence the current draw.
Also, if motor current is drawing higher current, then rewinding appears to have used larger diameter wire, or lesser length (fewer turns) either of which will change other motor characterisitics in addition to no-load current.
Belgium - Member - New Member
Good Answers: 21
08/31/2013 6:06 AM
Fewer turns will increase the no-loas current, but larger diameter wire will decrease the no-load current....
08/30/2013 1:17 AM
Measure it.
The exercise is a waste of time. Don't bother, you won't know what the data means anyway.
08/30/2013 4:42 AM
Ideally, the no-load current of all motors is zero. The reason is that if the motor is not doing anything, the best thing to do is switch it off.
Good Answers: 42
08/31/2013 2:11 AM
Not true.
For AC induction motors you have the magnetizing current, that aproaches a 90 deg phase shift. Depending on the motor, it may be 30% of the total full load current.
08/31/2013 3:57 PM
So, why not switch it off?
09/01/2013 12:22 AM
Dear Mr. PWSlack,
You are right, when Motor is switched off, current is zero. But when the motor is started, motor reachs rated speed, and it is not loaded, the current drawn by the motor,will follow the path of Circle Diagram, which you know, and during No-Load, you also know that the Power Factor will be very less.
Pl. explain your point further,
DHAYANANDHAN.S
Good Answers: 804
Re: No Load Current of Motors & Pumps
08/30/2013 10:46 AM
As you can see from the previous responses, this is mostly a fruitless exercise. There are no tables, no two motors of the same size but different models will have exactly the same no load current, it can range from 20-50% of the FLC depending on the motor design. The current that you measure with no load on the motor is at such a low power factor that it means next to nothing. The only possible value it has is specific to each individual motor as empirical data that is evaluated over time to detect a trending change that might indicate impending failure. Even then, it is subject to differences in applied voltage and current imbalances, so all of that would need to be tracked and logged concurrently, then used to adjust any findings. The value of that dims with the time and effort expended on it.
Besides, there is no direct correlation to unloaded current as a meaningful indicator of what the efficiency under load will be anyway. So trying to equivocate it is like trying to determine the fuel efficiency of a car that sits idling in a parking lot. What's the point? If it is doing no meaningful work, why is it still running?!
If what you are after is a way to determine whether or not to continue rewinding a motor or deciding to replace it because it is becoming too inefficient, the only proper way to do that is to measure the input kW (absorbed power) under a specific load and compare that to a known efficiency model that you have created with an optimum installation. A dynamometer is a good tool for that, but again, you have to weigh the costs of doing all of this against the potential gains from it. It might be easier to just make a record of every NEW motor installation under a specific loading (for example flow in a pump) and keep it as the efficiency model, then periodically check it against that model, or check it again it after each rewinding.
08/30/2013 11:12 PM
If motor manufacturers print the value of no load current in the motor name plate there won't be a problem. Why not BEAMA,NEMA,ISO do it?.
pnaban
Good Answers: 804
08/30/2013 11:19 PM
"Why not BEAMA,NEMA,ISO do it?."
Because:
  1. There is no value to the information
  2. If it is shown, ignorant people will be taken advantage of by unscrupulous salespeople who will try to use that information to make them believe there IS value to it, and that their numbers (higher or lower) mean something valuable compared to someone else' numbers (higher or lower).
Bottom line, it would just create needless confusion.
08/31/2013 12:06 AM
Value of no-load current of a new motor serves as a guideline for testing a motor after repairs,although it need not be exactly same due to damage to stator,bearing etc
pnaban
08/31/2013 3:33 AM
Thanks for your suggestion i have tried to get the no load current detail from motor manufacturerer & from internet but not find anything.now i have got somw brand new motors in our company i will checked there no load currrent & then compare it with the installed motor on machine.if suppose the no no load current is 30 percent high after replacing it i will gert the 30 percent energy dave. Is that s
08/31/2013 4:32 AM
Some manufacturers mention power factor,noise level,bearing sizes too in the name plate. Instead of writing to manufacturers or referring to their website users should get information at sight. Before internet was introduced imagine the situation-you write to them & wait?. I suggest to print size of capacitor required for PF correction as well as that for shunt capacitor type starter in the name plant.
pnaban
Good Answers: 34
08/31/2013 2:13 AM
Ashutosh, there is no mention of rating of motor in your message.
It is mono block pump hence could be a small motor.
It has been rewound 4 to 5 times.
It has lived its life better replace it.
If you are still keen, next time when it burns, after the stator is ceared of burnt winding, get a magnetising test on the core and you may find hot spots. This could be reason of increase of no load current and losses and could be frequent failures.
I will not suggest to re-insulate core plates, if hot spot is noticed - better in that case will be sell this in scrap and buy a new pump set. Reason for not insulating core plates being; 1. The core factor may become poor -> the rewinder will quietly remove few plates, this will have same effect - increased flux density -> increased no load (core) losses. Core may become loose in stator frame -> result in shifting with every start -> snapping of leads and short circuit. To avoid all subsequent problems - better to replace the pump motor set.
Good Answers: 42
08/31/2013 2:20 AM
Rewinding a motor should not significantly change its characteristics.
I used to work for Reliance Electric in their large AC motor plant in Canada. (500 to about 5000HP)
Occasionally we did do a rewind - burn out the old coils in an oven, and then rewind.
Depending on the insulation system, wire size, etc, you could actually end up with a superior motor.
08/31/2013 5:50 AM
Don't bother about the no load current. This varies widely from maker to maker and local conditions.
As already suggested, try to check the kW reading when pumping against the expected kW theoretically needed to transport the required flow under the back pressure (or to what height...). This will give the overall efficiency of pump-motor assembly. Check against the pump chart that the pump supplier should give.
09/01/2013 12:12 AM
Dear Mr. ashutosh goyal,
The No-Load Current will be in the range of 30% to 40% depending upon the Power Factor, and you draw the circle diagram, for your self and see. If it is above 40%, then re-winding is not proper and some error has taken place, knowingly or unknowingly.
DHAYANANDHAN.S
Hobbies - CNC - New Member
09/01/2013 1:11 AM
Poster,
There is a lot of information you left out of your question.
  1. Why do you need to know the no load current?
  2. If it is for reference, then do as earlier posters have suggested.
  3. What is the HP of the motor?
  4. What information is on the data plate on the motor?
  5. What type of pump is the motor connected to? (Centrifugal, Positive displacement, Etc?)
  6. What type of fluid are you pumping?
Why don't you do this,
  1. Measure the current with the motor running not connected to the pump.
  2. Measure the current with the motor running connected to the pump without fluid. Don't run it too long dry! Just long enough to get your current reading.
  3. Measure the current with the motor running and pumping fluid at your rated flow and back pressure.
You're going to get 3 different numbers and that is the data you want. Next time you have a technical question, we need as much information as possible to help us help you!
BA
Register to Reply 18 comments
ashutosh goyal (1); dhayanandhan (2); GW (2); JRaef (2); Just an Engineer (1); LAA_Lucke (1); lyn (1); Original_Macgyver (1); pnaban (3); powersolutionsFBD (1); PWSlack (2); rudy.leurs (1)
