Previous in Forum: Air Draft Chamber   Next in Forum: Solenoid Valves Learning Material Required
Flare Control and Monitoring System
09/03/2013 4:54 PM
Hi,
I'd like to ask about the general specification of flare system control and the process parameters to be monitored ?
what is the standard for that?
thanks
Re: Flare Control and Monitoring System
09/03/2013 5:33 PM
Have you looked anywhere yet, or is this your first stop?
What process parameters do you think need to be monitored ?
What does your engineer say?
Have you checked the API web site?
You seem to have many questions, many elementary.
09/04/2013 5:01 AM
yes I have searched some sites but I get confused some are talking about PLC system and interface with DCS some are talking about other types.
the process parameters may be the pressure or flow of the gas to avoid back flow also the flame monitoring using Temperture detectors or falme detectors
I didn't check API site I need the suitable API number
thanks
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
09/04/2013 12:42 PM
API Recommended Practice 521
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
09/04/2013 1:00 AM
Outside of API, if even there, I doubt that there is a general standard, partly on account of niche specialties.
Boiler control strategies would be a reasonable place to start. (Basically confirming that enough, but not too much, of air, fuel, and ignition source are present, and responding safely to deviations.)
Good Answers: 46
09/04/2013 1:08 AM
One good source of information on flare systems is the John Zink company. They have a number of documents you can download, which might help answer some of your questions:
http://www.johnzink.com/e-library/flare-systems/
All their free literature of course is geared toward the engineering and products they sell, but it's still useful for general learning.
a_m_shiha (1); lyn (1); tonykuphaldt (2); Tornado (1)
