Previous in Forum: C.G OF Gravity   Next in Forum: A Question About Pressure Vessels
Pressure Vessel Head
09/04/2013 3:49 AM
some time we use head thickness under pressure vessel.
t p=
PDK
2SE − 0.2P
some time we don not use K
WHY, when K is to calculte?
Re: pressure vessel head
09/04/2013 4:21 AM
Please explain how your Code defines "K".
09/05/2013 9:41 AM
When designing a pressure vessel head with pressure to the concave side, UG-32 of Section VIII, Div.1 is applicable. If an ellipsoidal, or torispherical, head is to be attached to the vessel and the minimum head thickness calculations, per UG-32, are found to have ts/L<0.002, we are directed to the Section VIII, Div, 1 rules of Mandatory Appendix 1, Part 1-4. In Part 1-4, K is a factor to be used in the formula (1) calculations for the minimum head thickness required. The values of Factor K are predicated upon D/2h, and are found in Table 1-4.1 of Mandatory Appendix 1.
09/05/2013 10:23 AM
Thanks! I no longer have access to a code copy. I think that GA should answer the OP's question, too.
Hobbies - CNC - New Member
Re: Pressure Vessel Head
09/05/2013 1:31 AM
Kryptonite?
BA
Original_Macgyver (1); Robert Johnson (1); Tornado (2)
