Previous in Forum: Pressure Vessel Head   Next in Forum: Size of Heat Plate Exchanger
15 comments
A Question About Pressure Vessels
09/04/2013 4:13 AM
there is any min distance requirement in asme code between two longitudinal and circumferential welding in vessel shell or head. ????
Re: pressure vessel
09/04/2013 4:23 AM
Not sure, but I think it is 50mm (2") between the closest parts of the two welds.
Good Answers: 183
Re: pressure vessel
09/04/2013 5:02 AM
In my humble opinion the distance should be related to the TAZ width which is at its turn related to the thickness and welding profile. It should be > 2 TAZ if not a weak zone is generated.
TAZ = thermally afected zone.
Re: pressure vessel
09/04/2013 5:37 AM
That's probably a better criterion than mine, though I think I have read mine in some code or spec. TAZ = HAZ (heat affected zone, as used in some other code languages).
Re: pressure vessel
09/04/2013 4:50 AM
It would be alarming to discover that pressure vessels are being designed and constructed without a copy of the relevant codes being to hand at the time.
Re: A Question About Pressure Vessels
09/04/2013 9:45 AM
Get a copy of the applicable specification and read it!
09/04/2013 10:08 AM
Keep in mind that hoop stresses are higher in a cylinder so your longitudinal welds had better be right or they will fail first!
Drew K
09/05/2013 3:38 AM
Having had experience with submarines - American and British - at both design and construction levels - that also involved other pressure vessels, the Rule of Thumb was and still is 3" or 80 mm. However, preheat treatment was executed to eliminate the effects of associated residual stresses.
Reply Score 1 for Off Topic
United States - Member - NE, USA Hobbies - Target Shooting - New Member Engineering Fields - Aerospace Engineering - Engineering Fields - Electromechanical Engineering - New Member
09/05/2013 9:10 AM
I don't know - but if I were working on the project - even just a theoretical one - I would get the spec and study every word of it!
Then I would know!
I guess a second option would be to anonymously ask the advice of strangers on the internet. That typically works out quite well!
09/05/2013 9:22 AM
Show me an anonymous poster who displays intelligence and I'll show you a miracle.
09/05/2013 9:48 AM
As for the Lyn person: There is no call for your belligerent aggression. Among the many things learned in my career, good communication may only be achieved without setting up barriers, such as your evident immature delivery of non-information.
Grow up, child.
Reply Off Topic (Score 7)
09/05/2013 9:40 AM
I wholeheartedly agree with your post: There is no substitute for valid specifications. However I stand by my original statement of which I am certain, and gleaned from said specifications and my extensive, tried and tested experience and practise.
09/05/2013 10:17 AM
From your extensive, tried and tested experience and practice, please explain the difference between weld preheating and post-weld heat treatment, in light of your first post.
09/05/2013 10:51 AM
Anonymous, The ASME Code, Dection VIII, Div. 1, Part UW addresses your issue. FIG. UW-3 illustrates pressure vessel welded joint locations typical of categories A,B,C, and D. Paragraph UW-9(d) states that unless the longitudinal joints are radiographed for a distance of 4" (100 mm) each side of each circumferential welded intersection, courses are to have the centers of the welded longitudinal joints staggered, or separated, by a distance of at least five times the thickness of the thicker plate.
09/05/2013 10:58 AM
Oops! Sorry, guys.. I should have reviewed my post more closely before submitting! I don't find my "Dection" VIII for verification. I did find my "Section" VIII, however. Slip of a hunt and peck finger, I guess.
Good Answers: 183
09/05/2013 2:24 PM
Thank you for this comment it reinforces what I wrote (although nobody appreciated it a s a good answer) since it is logical to consider the HAZ which is proportional to the thickness of the welded wall. The distance is such that the temperature in the zone of the new weld will not affect the first one. I assumed (based on heat conduction estimations for low carbon steel) that the HAZ could be around 2 x thickness. The value of 5 t supports my estimation. I am glad to notice once more that practice and theory go hand in hand although several participants do not appreciate a theoretical approach.
Reply to Forum Thread 15 comments
Drew K (1); JCase (1); lyn (2); Maltese-X (3); nick name (2); PWSlack (1); Robert Johnson (2); Tornado (3)
