Previous in Forum: A Question About Pressure Vessels   Next in Forum: Pressure Vessel
Size of Heat Plate Exchanger
09/04/2013 4:28 PM
Hi,
Does someone have a document, webpage, and so on... to estimate the size of a plate and frame heat exchager. I have all the information (temperatures, properties, heat exchanged,...)??
Thanks in Advance.
Re: Size of Heat Plate Exchanger
09/04/2013 4:36 PM
These are childishly simple to find.
All one has to do is perform a simple web search.
Heat Exchangers Designing(pdf)
PLATE AND FRAME HEAT EXCHANGERS - Thermopedia
Where did you look?
09/05/2013 4:04 AM
Yep. Plate-and-frame heat exchanger manufacturers have them, and will gladly do those calculations with a view to building a relationship and tendering a product. They will need to know the details of the fluids too, because liquid marmalade behaves differently from liquid sodium and each application will use different wetted materials.
Pick up the 'phone and make some calls.
Location: OHIO, tri-State design and installation, and travel nationally and consults also are international
09/06/2013 12:18 AM
like Lavalle
Simply choose your utility supplier contracting WITHOUT BROKERS and opt-out of community aggregations for free choices.
10/07/2013 2:14 PM
Thanks,
The best option was making some phone calls
Register to Reply 4 comments
ChemistUSX (1); JP76 (1); lyn (1); PWSlack (1)
