Previous in Forum: Polypropylene   Next in Forum: Contract Electronics Manufacturing Engineering
Sensor used in Manufacturing process
06/04/2007 2:57 PM
Folks,
We manufacture Transdermal patches in the pharmacautical industry and we use a particluar sensor to determine the gap between patchets on a continous reel. This gap is used to reference a servo based advance system which determines the cut position for the individual patches. We are using a SENSOPART FR 20 RG 1 which is a retro-reflective sensor working on the auto-collimation principle for transparent objects. The simplest way of describing what this sensor does is to imagine 2 transparent layers of material (eg. Cellotape) and the sensor has to pick up on the gap between these layers.
This sensor does the job once it is set up but it is hit and miss with regard the set up procedure. Anyone know of a better sensor that is easier to set up. ??
Any help is appreciated
RC
Pathfinder Tags: edge detection sensor transparent
Re: Sensor used in Manufacturing process
06/05/2007 5:59 AM
The companies in the links below have many technologies available, and may be able to help. http://www.micro-epsilon.com/ and http://www.keyence.com/
Good luck
06/05/2007 9:50 AM
If you say the sensor gives you repeatable/capable results when set-up properly, then your problem is not with the sensor, it is with your set-up procedure. Is the set-up problem with the sensor sensitivity/set-point or is it with mechanical position (which could be fixed easily with micrometer set-up)
06/05/2007 10:43 AM
As far as your existing sensor, I agree with Jonny5. I have a suggestion that could work as a sensor and as a quality inspection tool, but it would depend on if I understood you right. In the beginning you describe the patchets on a continuous reel, which I picture you detecting the leading edge or trailing edge of each patchet. But later your description makes it sound more like your detecting a gap between 2 layers in the same patchet, in which case I'm not sure how well this suggestion would work, but it would still be worth investigating. The company is called Cognex and they make image detection cameras. They actually bought out a competitor which had a product I liked, but even their works very well. Main differences are in how they use memory and speed. With these cameras, you can take a snapshot of what you want to detect and which is quality acceptable. From then on it will compare every new product to the parameters you have set. I've used the competitors for imaging pin receptacles in connector housings, using the cartesian coordinates that it feedsback to adjust and insert flexwire assemblies. Also have used Cognex for inspecting solder joints on ceramic hybrids which required the use of colored lighting to enhance the detection area. Just a suggestion that could you a bigger bang for the buck.
06/09/2007 7:49 PM
Imagine a roll of clear plastic laminate onto which we add a second layer of something that is very similar to a layer of cellotape. We cut the top layer into "squares". these squares remain on the lower roll of laminate and the excess "cellotape" outside of the square is removed. These 2 layers are then rolled together in a continous roll. This roll is then placed on a package machine which has to advance the roll a pre-defined amount so that we can cut the roll into individual segments comprising of our clear plastic laminate and the cellotape square. To ensure that we cut accurately between consecutive squares we must have a means of detecting where the squares (patches) begin and end. This is done by the sensor in the initial discussion. This sensor must be able to differentaite between a clear plastic laminate and a clear plastic laminate with a layer of cellotape (Our patch) on top if it.
Does this clear up what I am saying
Technical Fields - Technical Writing - Validation Specialist-Medical Devices United States - Member - From the Big Apple! Hobbies - Model Rocketry - Rockets should go nuclear! Fans of Old Computers - PDP 11 - Studied computers at W.H.Taft H.S., Bronx, NY. Popular Science - Cosmology - Radio Science Observing
01/02/2009 12:05 AM
Can a cat whisker be used instead of the elaborate style sensor you are using now?
WARNING! All suggestions are informative only. It is the prerogative of the user to implement under his sole responsibility. This commentator will not be liable for any damages or injuries incurred.
Alvin (1); Anonymous Poster (1); Jonny5 (1); ronald (1); Sonave Sunsets (1)
