Previous in Forum: Knob and Tube Wiring   Next in Forum: Power System Stability
10 comments
Perkins Generator 220HE
09/09/2013 2:11 AM
Hi Guys
I'm working on a 1300 series Perkins generator 220 HE...220 Kva.....It totally refused to start...I have replaced the fuel filter, pressure pump and fuel system was vent out of Air, the power wizard display board is showing everything OK, with only one present event..Low battery charge, battery has been replaced, still refuse to start,,Can any one please help, cause I need to start or diagnose the cause
Re: Perkins generator 220HE
09/09/2013 3:22 AM
Good Answers: 444
Re: Perkins Generator 220HE
09/09/2013 11:19 AM
You told us what you replaced but you haven't told us what you mean by "totally refused to start". Does that mean it won't turnover, won't crank, won't fire, won't continue running, etc., etc.
Each of those conditions points to a different system and its associated components, so save us the twenty questions and tell us exactly what happens (if anything) when you hit the Start button, otherwise this discussion becomes a non-starter. No sense discussing the fuel system if the starting system won't even turn it over.
09/10/2013 12:13 AM
Its can crank via the power wizard control board, but can not fire, use quick start, its tend to fire but stops when the quick start finish.During the time of using the quick start, the RPM is 867, DC Volt...20,2 etc.those are the one I can remember
Good Answers: 181
09/10/2013 12:15 AM
Having gone through some of your previous posts. I wouldn't let you anywhere near a generator.
You haven't a clue what you are doing.
I just hope you don't charge for your services.
09/10/2013 12:29 AM
SURE, OK that's your view. Then what can u advise is the possible cause of engine failing to start
09/10/2013 7:29 AM
Check for a plugged exhaust system. What was condition when last operating. Did it stop on it's own? Was it running satisfactory when shut down then refused to fire? Did you crack a fuel line to see if any fuel was being delivered to injector on cranking?
09/10/2013 12:56 AM
Bad Battery? Check specific gravity with one of those plastic thingys and/or somehting that can read ESR of the battery.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
09/10/2013 3:04 AM
1. bad battery. you need 24v, 23v may work, but 20v will not work
2. air in the filters and fuel lines is the number one cause. otherwise diesels are bullet-proof in the sense that: air + fuel + compression = start.
3. can you fuel be old or polluted with dirt or water?
4. can the fuel filters be clogged?
BSEE but always learning
09/10/2013 8:21 AM
Possibly low compression if everything else is OK. Take a reading on that.
09/10/2013 8:43 AM
with cranking you can check the initial smoke color also you have to crack the atomizer fuel supply .please also check the fuel displacment is it sufficiant
love4everyone
Register to Reply 10 comments
1capybara (1); aishaamadumamariama (2); KeepItSimpleStupid (1); PWSlack (1); RAMConsult (1); rickwil (1); roy hammy (1); sohail0110 (1); TonyS (1)
