Previous in Forum: Heat Transfer: Plate Heating with Water Tube   Next in Forum: Design of Blind Flange
Completely Constraint Motion
09/10/2013 1:51 AM
does the rotary motion such as rotation of a cranks shaft comes under the completely constraint motion?
Pathfinder Tags: completely constraint motion
Re: completely constrained motion
09/10/2013 2:21 AM
"TYPES OF CONSTRAINED MOTIONS-
1) Completely Constrained Motion- when the motion between a pair is limited to a definite direction irrespective of the direction of force applied. Example- the motion of a square bar in a square hole.
2) Incompletely Constrained Motion- when the motion between a pair can take place in more than one direction. Example- a circular bar in a circular hole where the bar can either rotate or slide in the hole.
3) Successfully constrained motion- when the motion between a pair is such that the constrained motion is not completed by itself but by some other means. Example- piston reciprocating inside an engine cylinder."
https://sites.google.com/site/mechanicalstuff4u/contents-of-m/theory-of-machines-2/machines-and-mechanisms
Re: completely constraint motion
09/10/2013 5:09 AM
A Zen master would unask this question as being unmeaningful.
Register to Reply 2 comments
