Previous in Forum: Completely Constraint Motion   Next in Forum: Vacuum Pump Getting Chocked
Hobbies - CNC - New Member
Design of Blind Flange
09/10/2013 2:22 AM
I am looking for the design calculations for a circular blind flange for a water pipe. The calculations given in the BS and ASME specifications are empirical.
The tables also cover only a limited range.
None of my engineering textbooks cover circular flanges either, and it seems my mathematical skills and knowledge has become rusted over the years.
Please help!
I will greatly appreciate your inputs.
Johan van Niekerk
Re: Design of blind flange
09/10/2013 3:25 AM
Blind flanges do not need local design. They need selection from published tables.
09/11/2013 2:02 AM
It is OK to admit you do not know either.
I need to know however since the information I require is not contained in the general tables.
Johan.
Johan van Niekerk
Good Answers: 122
Re: Design of Blind Flange
09/11/2013 8:50 AM
Do an internet search on "Engineering Toolbox" and look at the information available on this subject as well as many other subjects.
Good Answers: 38
09/11/2013 1:47 PM
Johan,
You have to make a distinction between a "blind flange", which is a permanent device in a piping system and conforms to the dimensions given in ASME B16.5 and a "test or hydro blind" which is what, I believe, that you want.
"Blind flanges" are termination points installed in pipework to allow a future extension of the system.
"Test blinds" are temporary flanges, used only for the test and need not be made from the same material as the piping system. They are designed to a higher allowable stress than blind flanges. There are code equations in ASME B31.1 and B31.3 regarding the thickness of these components. ( Check your stolen copy of this code)
Another type of permanent blind called "spectacle blind" exists and is used for maintenance purposes.
Good Answers: 67
09/24/2013 10:29 AM
The blind test flange thickness can also be used permanently (made of compatible material for fluid). The excel calculators can be used/made to know it. Just feed OD & thickness of pipe and pressure, you can get thickness required.
Johan van Niekerk (1); MJCronin (1); pritam (1); PWSlack (1); SHOCKHISCAN (1)
