Previous in Forum: Vacuum Pump Getting Chocked   Next in Forum: Digital Outputs Of Instruments
9 comments
Instrumentation - Design for LP Separator with PSH and LSH
09/10/2013 10:18 AM
Hello! I am new in Instrumentation but I am an expert in Electrical Engineering.Please I want an explanation for the diagram depicted above.Basically its a design for LP separator with PSH(Pressure Safety High) and LSH(Level Safety High).I want an explanation on how it shut the LP separator inlet valve when there is a PSH and LSH.
Dear all,
For designing a control systems in a flow station what are the steps taken:Basically,the flow station has a line heater hp separator,lp separator and a st orage tank but this time there will be an upgrade so tthere will be an addition of surge vessel,water treatment plant,gas scrubber,pumps and test separator
Pathfinder Tags: Low Pressure Separator
Re: Instrumentation - Design for LP Separator with PSH and LSH
09/10/2013 10:49 AM
<...how it shut the LP separator inlet valve when there is a PSH and LSH...>
If S were to stand for "switch" instead, then it becomes quite simple. Each device, when the process parameter goes from the normal to the high condition, opens a contact that, when closed, holds the LP separator inlet valve open.
There may be a bit more to it than that. Look for three documents: the first is the HazOp Study report, the second the Control Philosophy document written by the Process Design Engineer, and the third is the Functional Design Specification document written in response to it by the Controls Design Engineer. The detail of the arrangements will be found within at least one of the three.
<...what are the steps taken:Basically,the flow station has a line heater hp separator,lp separator and a st orage tank but this time there will be an upgrade so tthere will be an addition of surge vessel,water treatment plant,gas scrubber,pumps and test separator...>
The detail of this will be found in at least two of the three documents above.
09/10/2013 11:08 AM
The document I have is the symbol legend sheet,cause and effect matrix,control panel schematic-ESD and FIRE Module,HP separator module and LP separator module.Please PWSlack which API standard or design parameters should I used to design the for the upgrade.Thanks
09/10/2013 5:16 PM
It can't be done without the "approved for construction" Control Philosophy and the same-stamping P&IDs, both of which should have been passed through the HazOp Study before approval.
Stop work until these documents are to hand, otherwise it will all end in tears.
Good Answers: 176
09/10/2013 5:32 PM
PWSlack's observation is almost certainly the case; PSH and LSH are almost certainly Pressure Switch High and Level Switch Low, by ISA-5.1-1984 (R1992), Formerly ANSI/ISA-5.1-1984 (R1992), section 5.3.
09/11/2013 2:47 AM
Yes,I have the Upgraded P&ID that has Test Separator,HP,LP,Surge Vessel,Settling Tank,Storage Tank,Water Treatment Plant.The information I need is the design parameter basis I need to design a pneumatic control for the aforementioned.Please send me your mail so that I will send you the P&ID I developed.Thanks
09/11/2013 3:08 AM
Declined.
The Client needs to approve the P&ID "for construction", and the Process Engineer needs to write the Control Philosophy before any further work takes place. Otherwise it will all end in tears, as indicated earlier.
<unsubscribes>
09/11/2013 3:16 AM
The Client has approved the P&ID for construction and the control philosophy has been written by Process Engineer.So what is the next step.
09/11/2013 3:24 AM
<re-subscribes>
Write the Functional Design Specification, and pursue approval.
<re-unsubscribes>
09/12/2013 10:07 AM
Please can you design this kind of pneumatic panel.
Register to Reply 9 comments
desmond2013 (4); Iris (1); PWSlack (4)
