Previous in Forum: Elbow Pad Pad Forming Procedure   Next in Forum: IT DataCenter Equipment Row Separation
Chemical Injection Skids
09/16/2013 3:59 AM
Dear Sir/Madam,
GOOD DAY
Can you tell me about chemcial injection skids application and how to calculate the pipe size.
Best Regard's
B.Kumar
CR4 Admin - phone number removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Re: CHEMICAL INJECTION SKIDS
09/16/2013 4:11 AM
Use Google (other search engines are available) to source chemical injection skids, and then contact manufacturers directly.
Pipe sizing for a chemical injection line is the same as for any other process fluid:
  • Keep the average velocity between 1 and 3ms-1 subject to their being a lower practical limit on the pipe size for mechanical strength, support and damage limitation. If in doubt, follow the piping standard published by the Client organisation.
India - Member - Mechanical Engineer Engineering Fields - Petroleum Engineering - Mechanical Engineer
Re: Chemical Injection Skids
09/18/2013 8:54 AM
Dear Kumar,
Kindly ensure to specify the purpose of the system. You have chemical injection for various systems like oil, water, etc.
Please be specific to get specific answers.
Varun Passi
Register to Reply 3 comments
lyn (1); PWSlack (1); varunpassi (1)
